20 Most Recent
Samsung Xpress SL-C460FW Laser Multifunction Printer - Color - Plain Paper Print - Desktop Copier/Fax/Printer/Scanner - 19 ppm Mono/4 ppm Color Print - 2400 x 600 dpi Print - 19 cpm Mono/4 cpm Color Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150 Questions & Answers
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
How do I set up on my printer to connect fax
Dear
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Thanks,.
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
My printer spoler is not working
Hi g k,Have you tried restarting the print spooler from services?Start the Print Spooler service from the Services console
- Click Start, click Run, type services.msc, and then click OK.
- Right-click the Print Spooler service, and then click Stop.
- Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
- Click Start, click Run, type cmd, and then click OK.
- Type the following commands at the command prompt:
net stop spooler
net start spooler
exit
Note Press ENTER after each command line.
Hope this helps, and please rate:)Gary
