20 Most Recent
Garmin nuvi 55LM 5" GPS with Lifetime Map Updates Questions & Answers
Garmin Nuvii 55 LM battery icon color meaning
There are usually 4 side by side green bars if the battery is fully charged. You can think of each bar as 25% power, so (4) bars is 100%, (3) bars is 75%, (2) bars is 50% and (1) bar is 25%.
Why won't Satnav turn on?
Hold the power button in for at least 30 seconds while externally powered. Some of the units have software problems if they are shutdown using the power button instead of letting them auto-shutoff when you remove DC (shut off your car).
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
My garmin nuvi says system sofeware missing
Download Garmin Express from Garmin and install to your PC. Plug your GPS into your PC, Garmin Express should identify your GPS and give you options to update maps and software.
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
