20 Most Recent
Polaroid Is426 16 Megapixel Compact Camera - Red - 2.4" Lcd - 4x Optical Zoom - Pictbridge IS426RED Questions & Answers
Videos recording but no sound why
check the small hole of the microphone at the camera body if it is filled with dirt, clean it with a toothpick like things, do not insert much in. and don't use needle. still problem open, change microphone.
How to delete pictures off camera ?
Two methods, one if this function is installed on your camera you can choose to format the card which will delete everything on the card.
Two if the above is not available you can put your card in your computer if there is a slot for it or connect your camera via USB to your computer. Locate the memory card and format it to remove everything, this is faster than choosing the delete option.
Camera not working
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
Polaroid iD1660 not accepting memory card
you dont say what size or type of card you have there? did you previously use the card elsewhere? format the card on a PC using SDFORMATTER (google it) hope that sorts.
