20 Most Recent
Acer H236HL 23" LED LCD Monitor - 16:9 - 5 ms Adjustable Display Angle - 1920 x 1080 - 16.7 Million Colors - 250 Nit - 100,000,000:1 - Full HD - DVI - HDMI - VGA - 26 W - Black - MPR II Questions & Answers
My acer monitor H236HL is flickering. my brightness is set to 100%. I've turn eff the power off & on but it doesn't help.
check that all the cables are properly connected, if possible test the monitor on another computer.
if the problem persist when connected to another computer, the problem is in the display itself. You could try going into the menu, and resetting it to factory defaults.
if that doesn't help the problem is most likely inside the display, possibly some of the components on the powersupply are worn out. Capacitors typically, which might need to be replaced in order to get rid of the problem.
the problem can also be in the settings of the computer, but if noting has been changed recently then its unlikely.
you can also try another cable, since the display has more than one way to connect to the computer, you could try another type of cable that fits the display and your computer.
if the display is still covered by warranty, after you have checked that the problem is not being caused by the settings of the monitor or by your computer, then you might want to get in touch with your dealer to arrange service / warranty replacement.
Hope it helps.
Ekse
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
