20 Most Recent Zanussi ZWH6160P White 60 cm Washer Front Loading, 7 kg, A Energy Rating Questions & Answers
My zanussi zwh 6160p lets the water into wash but the drum won't move, I've checked the belt, motor and all seems ok, what could it be
if its around six years old it could be worn motor brushes not too expensive to buy or replace depending on yours skill levels.
10/2/2016 7:48:19 PM • Zanussi ZWH6160P... • Answered on Oct 02, 2016
Need dimension of Zanussi Aqua cycle 400
1/4/2024 9:07:00 PM • Zanussi Washing... • Answered on Jan 04, 2024
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty. Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums. Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
12/5/2023 9:07:17 PM • Zanussi Washing... • Answered on Dec 05, 2023
Zanussi ZWF1640 - at start of wash, all the lights go off and it jumps to end of cycle
May try resetting the breaker turning off turn on
9/1/2023 7:50:24 PM • Zanussi Washing... • Answered on Sep 01, 2023
Zanussi ZWF1021W Washing Machine bearing replacement?
Take a look at the videos. You will need a bearing and seal kit, plus some grease. You can knock the old bearing out using a large socket on an extension bar. That is also useful for gently seating the seal without damaging it. https://www.google.com/search?q=Zanussi+ZWF1021W+Washing+Machine+bearing+replacement Later machines have the bearings bonded to the drum. Truly a bad idea! https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/washing-machine-help-forum/31703-zanussi-zwf1431w-bearing-replacement ..
7/28/2023 4:03:25 PM • Zanussi Washing... • Answered on Jul 28, 2023
Zanussi washing machine door seal metal wire ring has come off, how do I put it back?
To put back the metal wire ring on the door seal of your Zanussi washing machine, you can follow these steps: Ensure safety: Before starting any repair work, make sure the washing machine is unplugged from the power source to avoid any accidents. Locate the groove: Examine the door seal and locate the groove where the metal wire ring needs to be inserted. The wire ring typically fits into a groove on the inner edge of the seal. Position the wire ring: Take the wire ring and position it in your hands so that it forms a complete circle. Make sure the ends of the wire are close together. Start at the top: Begin by inserting one end of the wire ring into the groove at the top of the door seal. Apply gentle pressure and work your way around, pushing the wire into the groove. Use your fingers or pliers: Depending on the size and tightness of the wire ring, you may be able to push it into the groove using your fingers. If it's difficult to do so, you can carefully use a pair of pliers to assist you. Be cautious not to damage the wire or the door seal during this process. Continue around the seal: Slowly and steadily work your way around the door seal, pushing the wire ring into the groove. Take your time to ensure that the wire is securely in place and properly seated within the groove. Double-check the installation: Once you've inserted the entire wire ring into the groove, double-check that it is evenly positioned and properly seated. Ensure that it's securely holding the door seal in place. I'm Sophia and CEO of Homyclean, and I love sharing my amazing cleaning, laundry, bathroom, best washing machine cleaners and maintenance experiences with you. I'll share hassle-free methods and top-notch products for washing and cleaning, fueling your passion for cleanliness. By following these steps, you should be able to successfully put the metal wire ring back on the door seal of your Zanussi washing machine. If you encounter any difficulties or the wire ring doesn't fit properly, it's advisable to consult the manufacturer's manual or seek assistance from a professional technician.
7/2/2023 5:45:55 AM • Zanussi Washing... • Answered on Jul 02, 2023
Zanussi Lindo 300..keeps adding water to finishing spin cycle
If your Zanussi Lindo 300 washing machine keeps adding water to the finishing spin cycle, there may be a few possible causes. Here are some steps you can try to diagnose and fix the problem:
  1. Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
  2. Check the Water Inlet Valve: The water inlet valve may be faulty, which can cause the washer to continue adding water. You can try cleaning the valve or replacing it if it is faulty.
  3. Check the Pressure Switch: The pressure switch controls the water level in the washer. If it is faulty, it can cause the washer to continue adding water. Try cleaning the switch or replacing it if it is faulty.
  4. Check the Control Board: The control board is the brain of the washer and controls all the functions. If it is faulty, it can cause the washer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
  5. Check the Door Lock: The door lock may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try cleaning the lock or replacing it if it is faulty.
  6. Check the Motor: The motor may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try resetting the motor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer thoroughly and ensure that it is working correctly and safely.
3/9/2023 2:27:42 PM • Zanussi Washing... • Answered on Mar 09, 2023
ZWH 7149 P won't agitate.
Either one of these. Control board has failed. Control knob has failed. Motor has failed. Motor controller has failed. If you can hear the motor turning, the coupler has failed. You need a service call to get correct diagnostics and warranty on the repair. The video _may_ help? https://www.google.com/search?q=Zanussi+ZWH+7149+drum+not+turning ..
10/29/2022 6:08:43 PM • Zanussi Washing... • Answered on Oct 29, 2022
Zanussi drains after pre wash but does not drain next cycle
This is a logic board issue. Call for service for the correct diagnosis and warranty on the new part.
10/13/2022 3:36:19 PM • Zanussi Washing... • Answered on Oct 13, 2022
Zanussi Aquacycle 1100 XC - when trying to start the machine the door clicks 3 times and then I get a error / beeping sound.
Hi, Please clean out the interior of your machines and clean any filters as necessary, then attempt to run again. If this continues, please call Zanussi at 03445 610 645 to help overcome the issue. Thank you.
9/30/2022 7:51:29 PM • Zanussi Washing... • Answered on Sep 30, 2022
Zanussi FJS1197W washing machine periodically wont drain at end of wash phase
It is very unusual for a front loader, it does have both a recirculation pump and a drain pump! I don't see any diverter valves. Exploded parts diagram. https://www.ransomspares.co.uk/parts/brands/zanussi/washing-machines/fjs1197w%20%2891478851400%29/ ..
7/24/2022 10:30:56 PM • Zanussi Washing... • Answered on Jul 24, 2022
Zanussi Lindo 300 tumble dryer buttons not responding!
The machine has a Diagnostics Mode if you can get to it. It also has a Reset https://www.google.com/search?q=Zanussi+lindo+300+reset ...
6/18/2022 3:55:34 PM • Zanussi Washing... • Answered on Jun 18, 2022
How to remove control panel on zanussi ZCM700X
video in the link. Manual if you need it, but no service manual. https://www.google.com/search?q=remove+control+panel+on+zanussi+ZCM700X ..
5/26/2022 4:12:48 PM • Zanussi Washing... • Answered on May 26, 2022
Zanussi washing machine zwnb6140 spin problem
4/20/2022 3:09:39 PM • Zanussi Washing... • Answered on Apr 20, 2022
My zanussi dish washer keeps cutting out mid cycle it's a zdv 1200
Strange, I just replied to a question for a ZDF1200 WASHER. https://www.google.com/search?q=Zanussi+ZDV+1200%2C+stops+mid+cycle ..
3/14/2022 6:11:41 PM • Zanussi Washing... • Answered on Mar 14, 2022
I have a Zanussi ZWF16070W1 washing machine which keeps on stopping shortley after it has filled with water. The flash/error code is 5red and 4 green. Does anybody know what this means, please
What you need to do is check the filter in the bottom right hand corner. You need to clear this and in the back were the filter goes you will see the pump impeller X shape. Make sure theres nothing jammed up in there stopping it from turning
2/24/2022 11:00:00 AM • Zanussi Washing... • Answered on Feb 24, 2022
Zanussi Lindo 100 dryer - stops after 10 seconds, pauses 1min, runs 10secs.......
This is what happens during wrinkle guard. During the end of the cycle a dryer will go into wrinkle guard to protect clothes from being wrinkled. Either the timer is stuck in this position or it is set in this position. Wrinkle guard can be called different names depending on manufacture.
2/23/2022 9:13:37 AM • Zanussi Washing... • Answered on Feb 23, 2022
2answers
Zanussi washer zwh8 100se. Message EH0 and E40?
Zanussi Washing Machine Error Code = E40
?Error Code Definition = The washer door is either open or not properly closed.?
What To Check or Repair = Check that the door is completely closed. Check that nothing is blocking the door from closing.
Zanussi Washing Machine Error Code = EH0?
Error Code Definition = The electrical supply is not stable. Wait until the mains supply is stable.?
What To Check or Repair = Check electrical circuit breaker. Unplug the washer for 10 minutes to reset.
12/23/2021 12:00:35 PM • Zanussi Washing... • Answered on Dec 23, 2021
Zanussi ZWH6160P White 60 cm Washer Front Loading, 7 kg, A Energy Rating Logo
1 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
zanussi zwh 6160p lets water into wash
  • Washing Machines
