20 Most Recent Husqvarna Fast Tractor YTH24V48 48" 24HP Lawn Tractor 2014 Model - 960 43 01-82 Questions & Answers
How do you get the transmission to lock
These machines are usually hydro static transmissions. When you apply the parking brake they squeeze a disk inside of the transmission locking it with park brake. The procedure press brake tight and pull up on park brake lock lever.
12/6/2015 2:51:13 AM • Husqvarna Fast... • Answered on Dec 06, 2015
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
12/6/2015 2:10:34 AM • Husqvarna Fast... • Answered on Dec 06, 2015
Does this tractor have a locking Transmission?
yes
12/6/2015 2:10:24 AM • Husqvarna Fast... • Answered on Dec 06, 2015
2answers
24 hp,2014 husqvarna riding mower. trying to locate main fuse manual says under the dash but no joy.I want to start troubleshooting with the fuse! : Any ideas???
20 amp fuse,here is the diagram,find your wiring harness and look for it on the drivers side,its hard to describe,it is under the steering wheel,behind the battery. http www searspartsdirect com husqvarna riding mower tractor parts model... HUSQVARNA TRACTOR Parts Model 96043018200 Sears PartsDirect
4/13/2015 8:38:32 PM • Husqvarna Fast... • Answered on Apr 13, 2015
Why is the gas tank not venting ?
Did you check the top of the gas cap for tape over it top of gas cap should have a small hole all the way through it.take a small piece of wire see if you can push it through . you might have other issues. If it does not.take cap off and drill tiny hole through it .or send cap back where you bought mower explain you want a new cap.
5/18/2014 2:15:17 PM • Husqvarna Fast... • Answered on May 18, 2014
Trying to remove steering wheel but can't. Is there a locking device on the nut?
Its a lock nut. Will take a little more levage.
4/29/2014 12:48:18 AM • Husqvarna Fast... • Answered on Apr 29, 2014
How do I remove the steering wheel?
Remove cap on steering wheel, then remove nut.
4/29/2014 12:45:18 AM • Husqvarna Fast... • Answered on Apr 29, 2014
2answers
How do I find out what year my Husqvarna yth18542 42 in riding lawn mower was made in
yth18542 is the model number of the lawn tractor, the identification plate should also show a serial number, which can be used to identify the date of manufacture as well as to differentiate between differences in this model, depending on date of manufacture. https://www.husqvarna.com/us/products/riding-lawn-mowers/yth18542/960430172/
4/16/2024 6:17:40 AM • Husqvarna Garden • Answered on Apr 16, 2024
2answers
Governor on briggs 445677
Looks like your governor crank broke. Go to www.parttree.com
4/12/2024 1:16:56 AM • Husqvarna Garden • Answered on Apr 12, 2024
What kind of blade can i put on my Husqvarna 322L weedeater to cut little trees up to size 1/2 to 1?
copy and paste into search engine Husqvarna Blade Conversion 537048502 537 04 85-02 322L 323L 324LX 325LX 326L
3/21/2024 4:41:48 PM • Husqvarna Garden • Answered on Mar 21, 2024
2answers
I have a Husqvarna HU700F. I need a new grass bag. I can only find one for an HU700. Would that fit?
Here is the bag, use your existing frame https://saffordequipment.com/product/husqvarna-black-grass-bag-oem-580947302/ Husqvarna Black Grass Bag OEM #580947302 **Bag Only, Does not come with Frame** Compatibility This part is compatible with the following machines: Husqvarna HU700F (2012-11)(96145000900) Walk Behind Mower Also available at Walmart and Sears https://www.google.com/search?q=husqvarna+hu700f+grass+bag
OEM Husqvarna 580947307 Fabric Grass Bag ONLY For ...
Walmart https://www.walmart.com > OEM-Husqvarna-580947... Husqvarna. OEM Husqvarna 580947307 Fabric Grass Bag ONLY For HU550F HU550FH HU700F HU800H. USD Now $55.00. You save $14.58. You save$14.58. was $69.58$69.58. US$55.00 ..
1/28/2024 8:02:53 PM • Husqvarna Garden • Answered on Jan 28, 2024
Husqvarna YTA24V48 Lawn Tractor. Need drive belt diagram for it please?
Question edited for clarity. Shown on Page 20 of the manual. https://www.manualowl.com/m/Husqvarna/YTA24V48/Manual/493664?page=20 ..
11/29/2023 9:34:18 PM • Husqvarna Garden • Answered on Nov 29, 2023
Husqvarna zero turn 560 lawn mower how do I raise the seat
See attached. .. manual available at
https://www.husqvarna.com/us/support/z560x/
11/25/2023 1:15:01 PM • Husqvarna Garden • Answered on Nov 25, 2023
How do I pour gas into my carborator when I run out of gas
why, just fill tank
10/28/2023 8:18:43 PM • Husqvarna Garden • Answered on Oct 28, 2023
3answers
Husqvarna zero turn mower. Starts ok, but when I bring in the right handle the engine dies. The left is ok, I can move it in and go forward slightly with it, but when I engage the right handle the engine shuts off.
Your seat safety switch is not working. If the seat switch isn't activated, ie. a person sitting on the seat, the safety system will stop the engine when the levers are engaged. There is probably only one lever safety switch, on the right lever, which is why the left one doesn't kill the engine. Check the seat switch continuity and the wiring for loose connections.
10/7/2023 2:37:40 AM • Husqvarna Garden • Answered on Oct 07, 2023
2answers
Husqvarna RZ46i 46-in 23-HP V-twin Gas Zero-turn Riding Lawn Mower. It starts then engine revs up, no control.
Question edited for a lot more clarity! The throttle return spring has broken or come unattached. more here https://www.google.com/search?q=Husqvarna+RZ46i+runs+full+throttle ..
10/4/2023 12:05:24 PM • Husqvarna Garden • Answered on Oct 04, 2023
Slow forward drive on hydrostatic mower husqvarva 316 tsx awd
Likely there is air trapped in the system. Try raising drive wheels (safely) off the ground and operating forwards backwards. With minimal load on the hydo pump and motor, the air should purge.
9/22/2023 1:39:14 PM • Husqvarna Garden • Answered on Sep 22, 2023
2answers
Husqvarna 128CD weed eater. The flywheel is tight, piston is at bottom when flywheel magnet is in contact with coil. How can I change it to correct position.
The flywheel key has likely sheared. Contemporary utility 2-cycle flywheel keys are integrated into the flywheel. A new flywheel will be likely be required.
9/7/2023 10:16:53 AM • Husqvarna Garden • Answered on Sep 07, 2023
Husqvarna Fast Tractor YTH24V48 48" 24HP Lawn Tractor 2014 Model - 960 43 01-82 Logo
10 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
  • Garden
