20 Most Recent Bosch WAB28060GB Maxx White 600 mm Washer Front Loading, 5.5 kg, A Energy Rating Questions & Answers
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Bosch WAB28060GB... | Answered on Oct 22, 2016
Yes but there are different colour choices
Bosch WAB28060GB... | Answered on Jul 26, 2015
Door not detected closed
Check door is closed
Check door catch and latch
Check door lock
Bosch WAB28060GB... | Answered on Jul 12, 2015
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Bosch WAB28060GB... | Answered on Jun 21, 2015
Fabric conditioner causes blockages in the hose that supplies the tub. This occurs frequently on colder washing temperatures. Check the supply hose for gunk. Periodically run the machine on a hot cycle for cottons as an example as this action will also ensure that the deposits in the tub are also addressed.
Bosch WAB28060GB... | Answered on Apr 20, 2015
Blocked dispenser tube. You need to pull the drawer out ( There will be a clip that you depress in the centre of the drawer when open, that will allow you to slide the drawer out. Clean all the gunge out with a brush and hot water. BTW, if you reduce how much soap you use , you will probably find you don't need fabric softener. Clothes go hard and stiff from the amount of soap that is left in them after the wash has finished. IE/ Towels are the worst for absorbing soap in a machine. In rare cases, water hardness is a factor, but not usually.
Bosch WAB28060GB... | Answered on Mar 16, 2015
Water should fill to bottom of door . If not replace water level switch
Bosch WAB28060GB... | Answered on Aug 12, 2014
This may answer you question;
https://www.justanswer.co.uk/appliance/ah0vw-bosch-logixx-dishwasher-sms69l12gb-21-fd9010-check-water.html
Bosch Washing... | Answered on Feb 02, 2020
CONTACT LOCAL REPAIR SHOP ABOUT FIXING IT
Bosch Washing... | Answered on Jan 13, 2020
could be the door switch has failed . try leaning on door when starting .
Bosch Washing... | Answered on Jan 07, 2020
Bosch WAB28060GB Maxx White 600 mm Washer Front Loading, 5.5 kg, A Energy Rating Logo
Popular Tags
14 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
repair or parts manual
  • Washing Machines
