20 Most Recent
Westinghouse VR-6025Z 60" LCD TV 1920x1080, 120 Hz, HDTV Questions & Answers
Tv doesn't power on
hi i'd check the voltages on the connector on the power board, it sounds like you have 5v standby, i'd check for 12v and 24v or look for a tv tech in your area
regards
shaun
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
- Press the power button on your TV to turn it on.
- Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
- Look for the "Reset" option and select it.
- Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
- Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
Westinghouse WD55UW4620 no picture
Before you replace the power board, there are a few things you can try to troubleshoot the issue with your Westinghouse WD55UW4620 TV:
- Adjust the picture settings: It's possible that the picture settings on your TV have been accidentally adjusted, resulting in a dark picture. Try going into the TV's menu and adjusting the brightness, contrast, and other picture settings to see if that helps.
- Check the backlight: The backlight is responsible for illuminating the pixels on your TV screen, and if it's not working properly, it can result in a dark or dim picture. You can check the backlight by shining a flashlight on the screen and seeing if you can make out any images. If you can see images, then the backlight is likely the issue.
- Check the cables: Make sure that all the cables connecting your TV to external devices are securely plugged in and not damaged.
If none of these troubleshooting steps work, then it's possible that the power board is the issue. In that case, replacing the power board may fix the problem.
Backlights on Westinghouse WD50UC4300 TV flash and then go out.
It's possible that there is a problem with the protection circuit, especially if the backlights are receiving the correct voltage but are still not functioning properly. You could try checking the fuses or diodes on the circuit board that are responsible for protecting the backlights. It's also possible that there is a problem with the power supply or the main board that is causing the issue. If you're not comfortable working with electronics, it may be best to consult a professional for assistance.
Pass code for channel search on a Westinghouse tv model VR 4090
pass code's are typically setup by the user that sets up the tv. So, you could start my talking with that person first. If that person is not available, then you might need to factory reset your tv and setup it up again, provide the code to the tv and then write the code down (or email it to yourself) so you'll have it for future reference if you need it.
Thank you.
