20 Most Recent Pantech Link P7040 Black Rubber Feel Hard Case Cover wBelt Clip Questions & Answers
I can not change to the next song using LG hbs 7000 bluetooth on pantech 5000 cell phione
Hi, maye your bluetooth's button is not working.
4/7/2015 5:25:26 PM • Pantech Link... • Answered on Apr 07, 2015
Where is the easy mode and advanced mode on pantech link
Hi, I havent seen any mode,,,,sorry.
4/7/2015 5:24:10 PM • Pantech Link... • Answered on Apr 07, 2015
Stuck in initializing message
Hi, Keep stucked, or sell your phone on the OLX.
4/7/2015 5:20:16 PM • Pantech Link... • Answered on Apr 07, 2015
What ispuk code
PUK CODE IS PROVIDING BY THE SERVICE PROVIDER
7/20/2014 2:18:34 AM • Pantech Link... • Answered on Jul 20, 2014
Sim blocked, incorrect sim being used
HiPUK code is called as PERSONNAL UNBLOCKING KEY.Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK codeDONOT enter the PUK code several times wrongly,It will block your sim card permanently.This PUK code is FREE. You no need to pay any sum to get the PUK codeThank You.
11/20/2013 10:37:45 PM • Pantech Link... • Answered on Nov 20, 2013
My pantech will not send mms
CLICK HERE for the Pantech support page, for your model of phone, and follow their tips
10/19/2013 12:36:00 AM • Pantech Link... • Answered on Oct 19, 2013
Sim card locked on me
It's locked with Network? or locked with Security code?Security Lock means get the code from service provider and Reset it from Security lock of Sim!!! It locked to Network means specify the Network and Country it locked Now,then get the Network Unlock code for Pantech P7040 Link Phone at
Classicunlocking.com and Unlock it ,then use with any GHSM Network,To enter the code correct follow the Instructions below...
Pantech P7040 Link Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Pantech P7040 Link mobile phones. If you enter over a certain amount of wrong unlock codes on your Pantech P7040 Link mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Pantech P7040 Link with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech P7040 Link will display Unlock Process Complete. Press OK.
7. Your Pantech P7040 Link is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech P7040 Link.
10/11/2013 10:03:15 AM • Pantech Link... • Answered on Oct 11, 2013
Pantech Link P7040P "Initializing Message" Error
add 'conversations' to your shortcut list, go in through shortcuts menu and delete everything in there, ONE AT A TIME. hitting 'delete all' will freeze your phone. found this out on my own since no one knows what the hell is going on with these phones.
9/16/2013 5:31:41 PM • Pantech Link... • Answered on Sep 16, 2013
Water damages
open the back and put it into a bowl of rice, the rice soaks it up it should work, or put it into the hot press
8/15/2013 9:34:52 PM • Pantech Link... • Answered on Aug 15, 2013
2answers
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • 6/19/2013 3:45:20 AM • Pantech Link... • Answered on Jun 19, 2013
    2answers
    Unlock pantech
    It's simple to unlock the Mobile Phone from the Network Lock,You Pantech P7040 Link locked to which Country Network?You can get the Network Unlock code for Pantech P7040 model Phone at here Prounlocking.com and Unlock it from Network Lock step by step.Pantech P7040 Link Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Pantech P7040 Link mobile phones. If you enter over a certain amount of wrong unlock codes on your Pantech P7040 Link mobile phone, your phone may get hard locked and sometimes become unusable.1. Switch ON your Pantech P7040 Link with its ORIGINAL SIM card. 2. Type *#865625#. 3. A SIM Unlock Menu will appear, press OK. 4. Enter Unlock Code. 5. Re-enter Unlock Code. 6. Pantech P7040 Link will display Unlock Process Complete. Press OK. 7. Your Pantech P7040 Link is now unlocked. ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech P7040 Link.
    5/27/2013 8:01:23 AM • Pantech Link... • Answered on May 27, 2013
    Hard reset pantech p7040 without password
    its not possible without a passcode for security reasons.martyn
    4/11/2013 4:16:08 PM • Pantech Link... • Answered on Apr 11, 2013
    Micro sd card not reading
    This phone is only 3g...and the Sim cards for 3G and 4g cannot work in the same phones! hope this help.
    3/11/2013 7:17:13 PM • Pantech Link... • Answered on Mar 11, 2013
    Unlock pantech
    You can unlock the pantech P7040 using the unlock code,To get the unlock code you can visit the site Classicunlocking.com
    get the code and unlock it...you need to specify the Network it locked now,country.
    1/25/2013 7:43:43 AM • Pantech Link... • Answered on Jan 25, 2013
    2answers
    Unlock code?
    Try code from service provider or Go to Online site to Unlock it.they will give it.
    1/25/2013 5:12:58 AM • Pantech Link... • Answered on Jan 25, 2013
    Hi, I am trying to
    Hi, I can't provide that code but you can get your own pantech link p7040 unlock code from your network provider but you must have a good standing account with them (minimum 6 months contract). Other solution you can buy pantech unlock code from third party sites, which offering many unlock code from all network.
    1/25/2013 5:11:24 AM • Pantech Link... • Answered on Jan 25, 2013
    2answers
    I got pantech P7040 fro ebay and they said it was
    You can get the Unlock code at reliable cost at here
    http://www.unlocking4u.com/pantech-p7040-link/rs6wp9/ and unlock the Pantech P7040 Link.
    1/25/2013 5:10:50 AM • Pantech Link... • Answered on Jan 25, 2013
    Pantech Link P7040 Black Rubber Feel Hard Case Cover wBelt Clip Logo
    Popular Tags
    147 questions posted
    Top Pantech Cell Phones Experts
    ADMIN Andrew
    ADMIN Andrew
     Mikey
    Mikey
    Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    Pantech Cell Phones
    • Pantech Cell Phones
    Most Popular Question
    text messages send but 39 t view in
    • Cell Phones
