20 Most Recent Toshiba 61HX70 61" Rear Projection Television Questions & Answers
Yellowish green hump/curve at bottom of screen. Blue is at fault
Easy one of the two convergance chips
has failed .they cost about 10-30$ etch
so dont let them over charge you ,if
you decide to get it repaired
1/10/2017 12:37:52 AM • Toshiba 61HX70... • Answered on Jan 10, 2017
Overlapping images
If there's a Horizontal adjust on the back of the TV, turning that might help.. The horizontal is high voltage, maybe 800V so you probably need to send it to a shop for repair.
12/13/2013 4:47:06 PM • Toshiba 61HX70... • Answered on Dec 13, 2013
Audio but No Picture!
Unless you are absolutlyey sure that the value is correct on the resistor replacement I would put the original back in if it still checks good. I could not get you a Service Manual, but I do have a nice trouble shooting guide that I can send you. I just need your e mail.
5/8/2012 12:37:59 PM • Toshiba 61HX70... • Answered on May 08, 2012
No s-video connection
the set is not capable of this type of connection
4/16/2012 1:09:15 PM • Toshiba 61HX70... • Answered on Apr 16, 2012
Hi, I have Toshiba 61HX70. There is no picture.
Take a look at my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help solving this problem.
Thanks for using FixYa and for the great rating.
hardrocko
9/6/2011 8:33:46 PM • Toshiba 61HX70... • Answered on Sep 06, 2011
2answers
I don't know the security
While in the security code entering mode press the RECALL Button 4 times within 5 seconds to reset/remove the code.
If you need any further assistance then just ask.
Cheers
Andy
7/12/2011 8:02:59 PM • Toshiba 61HX70... • Answered on Jul 12, 2011
When i am watching tv
Try and reset all the setting to factory default setting and see whether it helps! If not then there should be a hardware issue that needs to be looked into. It is advisable to contact the manufacturer certified technician if you are still in warranty or a local mechanic if you are not in warranty. Good luck!
6/12/2011 2:04:27 AM • Toshiba 61HX70... • Answered on Jun 12, 2011
Was told power unit had
If you are handy with a soldering iron you can do the repair yourself. 90% of power problems stem from cracked solder joints on power board & convergence board. All you need to do is heat up the existing solder and add a little fresh solder to the joint. I had a power problem on my Toshiba 50". Service guy told me a new board would be $165 + $150 for labor. I wasn't paying that so before trashing it I grabbed my soldering iron and resoldered every joint on the power board and convergence board. Bingo! No more power problem and it only cost me $25 in supplies.
10/7/2010 7:55:18 PM • Toshiba 61HX70... • Answered on Oct 07, 2010
CONVERGANCE OUT OF WACK, RED
If convergence is skewed and or will not adjust both of the STK-392-110 IC CHIPS this set should use need to be replaced.
In most of the Toshiba sets they are on metal heat sinks with fins near the middle of the set, side by side.
There are also right in front of them some protect resistors--most will have color bands that indicate value----most common value is 1.8 ohm (like a short or good fuse---no reading and it is gone.
This is not the most easy set to get at the parts but if you want to attempt is as A DO IT YOURSELF repair I can assist you--Total parts cost on EBAY will be under 25 dollars and I can tell you what you will need and how to approach the fix.
I attach photo of what chips look like and photo of typical convergence problem.
If this information helped or told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Typical convergence chips and in front of them protect resistors.
Typical convergence problem, no two sets will look exactly the same.
8/22/2010 9:13:52 PM • Toshiba 61HX70... • Answered on Aug 22, 2010
Convergence of colors
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
8/14/2010 5:12:35 AM • Toshiba 61HX70... • Answered on Aug 14, 2010
A friend bumped into my Toshiba 61HX70. Now the
Convergence is off. A tech can help resolve the issue.
5/28/2010 7:49:23 AM • Toshiba 61HX70... • Answered on May 28, 2010
tip
Toshiba 61HX70 Service Manual Download
Download Toshiba 61HX70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 61HX70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 61HX70 Manual Download
tip
Download Toshiba 61HX70 Projection Television Manual
Have you misplaced your Toshiba 61HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television instructions.
I hope that helps.
Toshiba 61hx70 picture bounces and goes in and out of distortion
Most likely bulbs are failing and dirt and dust are caught up in cooling fans and in the projector of the set.
4/15/2010 4:26:41 AM • Toshiba 61HX70... • Answered on Apr 15, 2010
House was struck by lightening? power light comes
Needs repair. Probably melted a few transformers. Repair cost probably 200-300.
12/1/2009 6:49:59 AM • Toshiba 61HX70... • Answered on Dec 01, 2009
How do i fix my toshiba flat screen 57
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
11/23/2009 12:13:35 AM • Toshiba 61HX70... • Answered on Nov 23, 2009
2answers
My picture doesn't fit the
go to the menu, get into the "format" pix size they started this years ago you can re-size this per the sets manufacturer
10/25/2009 3:08:20 PM • Toshiba 61HX70... • Answered on Oct 25, 2009
Toshiba 61HX70 61" Rear Projection Television Logo
Popular Tags
48 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
don 39 t know security
  • Televison & Video
