20 Most Recent
Toshiba 50A60 50" Rear Projection Television Questions & Answers
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
I have a Toshiba Theaterview
There is no apreciable radiation from these tubed projectors unless the EHT supply exceed 33KV which is highly unlikely.
Replacing the screen could be quite costly though. Look up a Toshiba Repair agent for a price and maybe ebay as well.
Hope that helps.
Someone donated a toshibia 50A60 rear projection
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must be requiring to change 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board,to solved the tv convergence picture problems.Find some one in ur church can do basic electronic soldering,have all the tools?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit,also included a DVD disc for tutoring u how to do it that belong to ur tv make and model to repair it,the convergence problems by ur self.Or the shop,will cost u like $300-350 for parts and labors.
Good morning, I need to clean inside of my Toshiba
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Blinking red Light
Hi, thank you for visit fix ya.
Common problems on this tv ( cause no power):
1.- Loose connection between connectors and cool solder around fly back. ( re solder all).
2.- IC vertical output and capacitor in same section ( 100uf, 220uf,3300 uf and 2.2uf ), replace all.
3.- STKs ICs convergence , need be replace ( check any resistor around STKs, for burn or brown color).
----- Try to do step by step; you will repair your tv.
I will be here for any future question.
Thank you
No picture no sound
You will need to trouble shoot the various power supplies most likely something minor in either the stand by or start up circuits. I recommend that you get a service manual at the following link as they will email it to you and also help you diagnose it with free tech support. Here is the link.
http://servicemanuals.vstore.ca/
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
PIP
this tv does not have 2 tuners. So you will be unable to get 2 different channels on one screen. I have the same tv. The PIP is only good for watching a dvd/video and tv swapping only.
Toshiba 50
Your convergence ICs need to be replaced. Its an easy and cheap repair if you can solder. Parts will cost about 20.00 for both ICs
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
