20 Most Recent Singer 4411 - Heavy Duty Model Sewing Machine Questions & Answers
Why is needle hitting zipper foot on left side only?
When the needle is set on the center position, is it centered or is it slightly off center? If so, then the mechanism needs to be adjusted so that the needle is perfectly centered. When it is off-center, you will get the problem you are experiencing with hitting one side of the zipper foot. May want to take it in for service.
3/13/2016 3:36:59 AM • Singer 4411 -... • Answered on Mar 13, 2016
Why does not the machine sew When I finish winding the bobbin and return the bobbin spindle to left position ?
Did you place the bobbin back into the bobbin case? Need to clarify what you mean when it does not sew.
3/26/2015 5:11:43 AM • Singer 4411 -... • Answered on Mar 26, 2015
Can I use a vintage singer 161103 zigzagger attachment on a 201 k machine?
No I don't think it will. That attachment is for a 'Slant Shank' machine like a 301. The K on the Sewing machine model number simply means it was built in Scotland. That means it is basically the same as most other 201's.
4/16/2024 5:14:24 PM • Singer Sewing... • Answered 3 days ago
Singer Futura CE 150. I bought a used carriage unit attachment for it and the it drags really hard. It won't move at all while on the machine or when I take it off. Is there a way to fix it? Thanks
Question edited for clarity. Do you mean the embroidery unit. If it is secondhand and has been stored for a long time, sewing machine oil, or worse WD40 goes 'gummy'. You would need to clean all the out. WD40 is a good solvent, so spray, leave it to soak, spray again and agitate with a brush. The wash it all off with hot soapy water. Dry thoroughly and after a few days, lubricate metal parts with sewing machine oil and any plastic parts with a dry silicone spray like Jigaloo. Test Jigaloo on a flat piece of plastic first as it is also a powerful fast drying solvent.
Embroidery Unit, Singer #052007
Sewing Parts Online https://www.sewingpartsonline.com > products > embroi... Guaranteed to fit Singer Sewing Machine Models: CE-150 Futura III, CE-250 Futura III, CE-350 Futura III, SES1000 Futura III, SES2000 Futura III. Free · ‎ In stock https://www.google.com/search?q=Singer+Futura+CE-150+carriage+unit ..
4/15/2024 12:19:18 AM • Singer Sewing... • Answered on Apr 15, 2024
Singer Curvy flashing lights
I cannot see a question. Please include a question.
3/21/2024 8:00:29 AM • Singer Sewing... • Answered on Mar 21, 2024
Free manual for singer 8618
check if machine is threaded properly
3/8/2024 10:31:28 AM • Singer Sewing... • Answered on Mar 08, 2024
I have a singer quantum stylist 9980. When I turn it on, it beeps as usual but does not do the needle adjustment. It will not sew at all. How do I fix that?
  1. In the event that your Vocalist Quantum Beautician 9980 isn't playing out the needle change and won't sew, there could be a few issues. To begin with, guarantee the machine is strung accurately, and the bobbin is appropriately embedded. Check in the event that the needle is embedded accurately and not harmed. On the off chance that the issue continues, counsel the client manual for investigating tips or consider reaching Artist client assistance for additional help.
2/12/2024 1:57:13 AM • Singer Sewing... • Answered on Feb 12, 2024
Error 20 while trying to zip zag stitch 7 on my Singer Futura
Lois, all questions need full 'make model (what it is) please. Futura is a range of models so ''Singer Futura' isn't specific enough. Add the model number after the word 'Futura' and press enter.. You can also look for the Service Manual. There is one in the link, but no Error 20. https://www.google.com/search?q=Singer+Futura+Error+20 ..
2/7/2024 4:40:48 AM • Singer Sewing... • Answered on Feb 07, 2024
2answers
Singer Touch and Sew 756 feed dog gear replacement
DON'T cut lumps out of your machine. There will be a sequence you use to remove the parts you need to access to the gears more easily. The Youtuber you referred to sounds like they have zero knowledge when it comes to these older style machines. 'Note' Some of the gear mount nuts are on a "Reverse" thread meaning you turn them the 'wrong' way to get them off. My limited knowledge is more on the much older hand crank and treadle machines. Try the Youtube link below for a channel called 'Andy Tube'. He has a good reputation for correct repair methods. The link is for a 758 but they're both Touch and Sew machines. You could also try the Facebook group 'Vintage Singer Sewing Machines' as they have loads of knowledge about loads of different machines. https://www.youtube.com/watch?v=zxd5hKjGBlE
1/29/2024 9:27:54 AM • Singer Sewing... • Answered on Jan 29, 2024
Singer 4411 - Heavy Duty Model Sewing Machine Logo
3 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
not machine sew when finish winding
  • Sewing Machines
