20 Most Recent
Samsung DW80F600UTS 24" Stainless Steel Built-In Dishwasher 15 Place Settings, Energy Star Questions & Answers
Start button pressed , it starts to drain, you can see the water being drained but it does not cycle to wash
I'm presuming that the empty pump just runs constantly? If that's the case, then this is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
9/23/2015 5:31:03 PM •
Samsung...
Answered
on Sep 23, 2015
Smart auto and normal lights blink after the wash cycle and the unit shuts down
Hello. The error code you're getting is for a drain pump and water level sensor. Check the filter for obstructions such as food, glass, etc. when you "cancel/drain", does the washer in fact, drain? The drain pump very well might have a blockage or obstruction in it causing it to drain too slowly--especially if the drain hose has that notorious one-way valve in it(it's located inside the rubber boot of the drain hose that is clamped onto the drain pump. When the pump is active, there should be 120v at the connector going to the pump. If there is, and the pump is not working, the pump is defective. If there is *not* voltage, then suspect a broken wire or defective main board. I hope I helped you!
9/12/2015 1:45:21 PM •
Samsung...
Answered
on Sep 12, 2015
