20 Most Recent
Panasonic PT LC75E Multimedia Projector Questions & Answers
I just change the lamp but still the lamp hours shows the old timing
HelloYou have to reset the lamp time after lamp replacement. To reset lamp time follow these steps.[1] Press the power button, so that a picture is projected onto the screen.[2] Press the 'menu' button to display the 'main menu' screen, and press 'up' or 'down' buttons to move the cursor to select 'options-2'.[3] Press the 'enter' button to display the 'options-2' screen, and then use the 'up' and 'down' button to select 'lamp runtime'.[4] Press and hold 'enter' button for approximately 3 seconds. The 'lamp runtime' will change to 'time reset [power off]. Note: If the 'menu' button is pressed the lamp time resetting screen will be cancelled.[5] Hold down the 'power' buttonfor at least [0.5] seconds or press the 'power' button twice to turn oFF the power. This will reset the cumulative usage time for the lamp unit into Zero. OK.
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
Panasonic DP-C266 does not print one color
If your Panasonic DP-C266 copier is not printing yellow and you have already attempted some troubleshooting steps, here are a few additional suggestions to consider:
- Verify Toner Cartridge: Confirm that the yellow toner cartridge is installed correctly. Ensure it is securely inserted into the copier and that any protective seals or tabs have been removed from the cartridge.
- Check Toner Levels: Check the toner levels of the yellow cartridge. If the toner is low or depleted, replace the cartridge with a new one. Even if the toner appears to be full, it's possible that the cartridge may be defective or experiencing a blockage.
- Clean Developer Unit: The developer unit may have accumulated debris or become contaminated, leading to poor toner transfer. Open the front cover and locate the developer unit. Carefully remove it and clean it according to the manufacturer's instructions. Use a soft, lint-free cloth to remove any toner or debris. Avoid touching the developer roller with bare hands.
- Check Drum Unit: The drum unit may be damaged or worn, resulting in the poor transfer of yellow toner. Inspect the drum unit for any signs of damage, scratches, or wear. If necessary, replace the drum unit with a new one.
- Perform Color Calibration: Use the copier's built-in color calibration feature to ensure accurate color reproduction. Refer to the user manual for instructions on how to access and perform color calibration. This process can help correct any color imbalances.
- Service or Professional Help: If the issue persists after trying the above steps, it may require professional assistance. Contact Panasonic customer support or schedule a service visit by a qualified technician. They have the specialized tools and knowledge to diagnose and address specific issues with your copier model.
When contacting customer support or a technician, provide them with detailed information about the problem, including the steps you have already taken for troubleshooting. This will help them in providing more accurate assistance and guidance tailored to your specific situation.
Panasonic DP-MB250. How to remove Call Service 5 on it please?
The "Call Service 5" error on a Panasonic DP-MB250 generally indicates a problem with the fuser unit. Here are some steps you can try to resolve the issue:
- Turn off the machine and unplug it from the power source.
- Wait a few minutes to let the machine cool down.
- Open the front cover and remove the toner cartridge and drum unit.
- Locate the green lever on the fuser unit and gently push it towards the back of the machine to release the fuser unit.
- Carefully remove the fuser unit from the machine.
- Check for any paper jams or debris inside the fuser unit or around the rollers. If there is any obstruction, remove it carefully.
- Reinstall the fuser unit, drum unit and toner cartridge.
- Close the front cover and plug the machine back in.
- Turn on the machine and check if the error message has cleared.
If the error message persists, you may need to replace the fuser unit. Contact a certified technician for assistance.
