20 Most Recent
Delton X9 Thunder Behind-the-Head Stereo Bluetooth Headset with Music Controls Questions & Answers
Windows driver for delton x9
You don't need drivers for a bluetooth headset. You need a working bluetooth adapter in your computer (most laptops have it as standard, some desktops need an external one (USB dongle, and this comes with it's own drivers).
When you are sure that you have working bluetooth, you need to pair the headset with your computer.
You need to find the Bluetooth icon, looking like this:
in your system tray (near the clock on the taskbar, may need to click the << icon to expand the hidden icons). Right-click it and choose Add/Pair device and proceed to pair your headset per it's manual.
11/28/2014 12:15:46 AM •
Delton X9...
Answered
on Nov 28, 2014
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
19 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
