20 Most Recent TCL 50 Class LED HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, Clear Motion Index 120, 5000000:1 Dynamic, 8ms, 3x HDMI, VGA, Energy Star LE50FHDE3010 - LE50FHDE3010 Questions & Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
TCL 50 Class LED... | Answered on Aug 15, 2014
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
TCL 50 Class LED... | Answered on Jul 18, 2014
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
TCL 50 Class LED... | Answered on Jan 25, 2014
You are in the CHAINSAW section of FIXYA
Replace the power supply.
TCL Televison &... | Answered on Jun 24, 2014
It sounds that the main system control memory IC is faulty. Replace it and check. This is a very cheap to buy IC. Eventhough its cost and size is small, the function of it when the set is switched ON, is great. It is a very small IC, having only 8 solder terminals. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
TCL Televison &... | Answered on Oct 12, 2013
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
TCL Televison &... | Answered on Jun 27, 2012
You can't. Only basic controls can be done from the set itself unless you can get into Settings.
Google
make model replacement remote
companies now sell facsimile remotes which are identical to the original.
Televison &... | Answered 2 hours ago
TCL 50 Class LED HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, Clear Motion Index 120, 5000000:1 Dynamic, 8ms, 3x HDMI, VGA, Energy Star LE50FHDE3010 - LE50FHDE3010 Logo
7 questions posted
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
robert
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
tcl tv turns off while watching its own
  • Televison & Video
