20 Most Recent Vizio E420I-A0 42" LED TV 1920x1080, 120 Hz, HDTV Questions & Answers
How do I make picture fit screen. I tried increasing the picure under picture size under setup. Helped some but not enough.
Try by change the aspect ratio of the picture. Refer the user manual.
10/11/2016 12:36:57 PM • Vizio E420I-A0... • Answered on Oct 11, 2016
Vizio E420I-A0 no sound on hdmi
Try a firmware update. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
7/22/2016 4:59:38 PM • Vizio E420I-A0... • Answered on Jul 22, 2016
Why is my vizio smart tv keeps cutting off soon as you turn it on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/20/2016 12:18:52 PM • Vizio E420I-A0... • Answered on Jul 20, 2016
Vizio e420i-a0 picture problem. Vertical lines that progressively get brighter and sometimes the proper image displays but it is split vertically in 2 or 3 sections.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
5/10/2016 1:18:01 AM • Vizio E420I-A0... • Answered on May 10, 2016
Vizio E420I-A0 Black Screen
Check the attached links, "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Vizio E470i A0 Blank Screen No Backlights How to Test Power Supply... Testing TV Backlight LEDs Testing tv backlight leds EsBuzz net http://www.badcaps.net/forum/showthread.php?t=41334
5/4/2016 8:43:51 PM • Vizio E420I-A0... • Answered on May 04, 2016
My vizio tv has a black screen with sound. What could cause this problem and is it worth fixing.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/24/2016 5:49:23 PM • Vizio E420I-A0... • Answered on Apr 24, 2016
Black screen, audio, no backlight. What's wrong?
This is most likely a failure of the actual LED strips themselves. They do attach to a board at the edge, it could be the board but you have to order the board and strips as one unit. http://www.shopjimmy.com/lg-lc420dug-jfr1-led-strips-10-strips-1-board.htm
4/4/2016 11:03:27 PM • Vizio E420I-A0... • Answered on Apr 04, 2016
Why is there a dark tinted horizontal band through the middle one-third of the screen?
The T-con board is failing. You can get a replacement from here:
3/11/2016 8:41:46 PM • Vizio E420I-A0... • Answered on Mar 11, 2016
It has sound, but why no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
1/14/2016 7:03:18 AM • Vizio E420I-A0... • Answered on Jan 14, 2016
How do I access the APPS menu on my Vizio Smart TV without the remote?
You should have a remote control to access this function. It can't be accessed by its front control panel; by no way. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Type in the "brand name" of your device, in the search box [at the top right] of the display window to get gathered all the related posts to this brand devices. It will make surf easy.
6/19/2015 9:33:31 AM • Vizio E420I-A0... • Answered on Jun 19, 2015
0answers
0answers
Vizio V705-H1 started having display issues. The background seems okay but words have tracers.
Check Connections: Ensure that all cables connecting your TV to external devices (such as your cable box or gaming console) are securely plugged in. Loose connections can cause display anomalies. Test Different Devices or Apps: Try using other devices or apps with your TV to see if the issue persists. If the TV's menu looks fine but a specific device is causing trouble, that device might be the culprit. Adjust Picture Settings: Navigate to the picture settings by pressing the 'Menu' button on your remote. Experiment with different picture modes. Sometimes a minor adjustment can resolve display problems. Soft Power Cycle: Unplug your TV from the power source. Press and hold the power button on the TV for about 3-5 seconds (this helps drain any residual power). Plug the TV back in and turn it on. Some TVs also have a 'Soft Power Cycle' option in their settings menu, so check there too. As you have tried a reset, that takes us to the options of contacting Vizio support and/or your warranty.
4/19/2024 11:14:37 PM • Vizio Televison... • Answered on Apr 19, 2024
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
3/9/2024 5:42:30 AM • Vizio Televison... • Answered on Mar 09, 2024
How to see the time on my Vizio TV
No model number so generic advice only. Google 'vizio (model) manual'. ..
2/17/2024 10:59:24 PM • Vizio Televison... • Answered on Feb 17, 2024
Vizio E420I-A0 42" LED TV 1920x1080, 120 Hz, HDTV Logo
17 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
black screen audio no backlights way
  • Televison & Video
