Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted smsmessages from Android.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
I started getting this on a contact I had recently texted and received texts from. check sms restrictions 45 usually means it is an overseas # somehow the contact# which is not an international # had gotten a + in front of the number as if it was an international # how i dont know but after removing the + from the # in my contacts i was able to text the contact
Assuming you have inserted the SIM correctly(???), while the phone is "on", remove the battery, then replace. If that doesn't work, you will have to call TF customer service. Fortunately, the rep should be able to help you correct this, unlike other problems TF is clueless about.
IF DONE DOES NOT SHOW THEN MAYBE YOU CLICKED UPDATE CONTACT BY MISTAKE. Click " new contact"Type number > press options > save number > new contact > click done when finished.Try scrolling past some of the boxes where you can type until the "done" appears. Try adding info if that does not work.Try clicking options and then closing options, does done appear?
