20 Most Recent
Blu Diva X Mobile Phone Questions & Answers
Code for blu diva imei 351775052266840
try this one
Unlockitfree's Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 351775052266840 --
Your Nokia Master Code: 3215426060
^_^
How to adjust ring tone for diva x
Put into the phone SD card (some call it "memory card", small black one) with recorded music on it. Than follow the steps:
1. Open "Menu" and go to the "Organizer"
2. Scroll down to "File manager" and open it
3. Choose "Memory card" and open it
4. Scroll down to the "Sounds" (and choose what you like)
5. Press "Option" (down-left screen corner) and press "Use as"
6. Click on "Incoming call" and than press "Select"
On the screenplay will be "Done". And that's it !
Hope it was helpfull.
Setting am to pm on diva x blu
1. Open Menu
2. Go to Settings
3. Click (open) it
4. Scroll down to Phone settings and open it
5. Go to the Time and date
6. Click (open) it
7. Scroll down to the Set format - open it
8. You'll see Time with arrows options ( 24 and 12)
9. Press 12
10. Save it !
Hope it was helpful .
How i unlock my phone
Unfortunately without a password you have to reset it. Try looking somewhere for instructions on how to do a hard-reset (wipes all data and passwords :D) for that phone. Let me know if you need any more help!
-Mr. W
Sim card
Hi, a pair of tweezers can be great help in this situation. If you don't mind damaging the stuck sim card, try heating a pin and sliding it into the plastic of the sim card (be careful not to damage your phone) allow the plastic around the pin to set. Once set pull the pin and hopefully the sim will come with it.
Have Blu View 3 that can't make or receive calls, can you please help me?
I remember reading somewhere about an issue with so called off brand phones(Non-Flagship)... as im in the same boat(Using Cubot Brand) and talking with my service provider today. they stated my phone isnt on the list or compatable with the at&t network anymore(atleast the calling part of it) you should still be able to use data & text. Lucky i already have a third party app for a 2nd phone and also use google voice, both of which let me make calls using my data. and if i need to contact someone i can either send a voice/text message as normal.I have read somewhere that i believe blu is trying to get onto the att network. So hopefully they do because ill just switch back sense they are a good phone company. Hope this info helps.:Edit: Even if it is 4g LTE, also spoke with a friend who has a 5g non-flagship whos carrier uses att and she isnt able to make calls from the phone but the speeds are still there. So hopefully something gets fixed because I believe this is some B.S. to lock us out because we dont want to pay for a iphone or samsung
