20 Most Recent
Panasonic Panafax UF-550 Plain Paper Laser Fax Questions & Answers
The date is off, need
Hi there. Please follow the instructions below.
- Press FUNCTION , then 7
- Press 1
- Press SET
- Enter the new date and time
- Press SET then STOP.
If you make a mistake, press the left or right buttons to move the cursor to the incorrect number then enter the new number.
Hope this helps.
3/2/2011 6:35:40 PM •
Panasonic...
Answered
on Mar 02, 2011
I have a Panasonic Panafax uf-550 and I need to kn...
Apparently, you can set it for the default condition or you
can set it for the current fax you are sending.
To set the default:
1. Press "Function" then "74" then "Set"
2. Press "12" then "Set"
3. Press "1" for OFF
Press "2" for ALWAYS
Press "3" for INCOMPLETE only
4. Press "Set"
5. Press "Stop"
If you want to over-ride the default for the current fax,
1. Press "Function" then "8"
2. Press "1" then "Set"
Press "2" for ON (always print out)
4. Press "SET
Thanks to FixinFax for the clue for the default setting.
Alex Cook
7/23/2010 6:30:31 PM •
Panasonic...
Answered
on Jul 23, 2010
The
the switch is worn out. If you're handy with a soldering gun you can pop the op panel apart, unplug the board, remove 17 screws and swap the start switch with a little used switch such as RESOLUTION
4/19/2010 9:20:13 PM •
Panasonic...
Answered
on Apr 19, 2010
How to register number has been delete. How do you
press
function 72
set
press 01 on the soft key pad enter fax number
set
enter name with the letters on the soft key pad
set
continue with 02 as above or press stop
press
function
62 set to print diectory
3/24/2010 11:56:16 PM •
Panasonic...
Answered
on Mar 24, 2010
