20 Most Recent
Panasonic DP-150A Copier Questions & Answers
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Panasonic...
Answered
on Jun 20, 2013
How do I get the
Press auto/photo key, paper tray key, and one key sequentially to get into F mode. Press 7 and you will see F7. press start or okay the total count is under C02. Press auto/photo and clear/stop key to exit service mode. Hope this helps
Panasonic...
Answered
on Jul 20, 2011
U 1 error message
U1 is a right cover open error. So either that cover is not closed all the way, the tab on the door itself is not hitting the sensor that detects if it is closed, the sensor itself isn't working properly and lastly it could be board malfunctions. Most times on this model it is either a broken tab on the door or it is not shutting correctly. The front door has to be completely shut before the right door will shut. If you are looking at the right dooor straight on the sensor is at the bottom left corner of the machine. There is a little **** in the plastic that is where the sensor is. There is a piece of plastic on a spring that is on a guide that slides back when "triggered" some times that can come off the guide.
Hope this helps.
Panasonic...
Answered
on Dec 31, 2008
Panasonic DP 150
well, it means that you still have a pending job (fax).
if you really want to erase all the jobs, you must enter to the service mode.
press:
fax button
function
7
monitor (4 times)
asterisk(*)
find for ram initialize
find for all job clear
note: must be sure to select the "all job clear" only
set.
restart your machine
i hope this could help
Panasonic...
Answered
on Aug 22, 2008
Paper jam
If it crumbles just before the exit, then the problem is with the fuser unit, there are 4-6 claws/teeth/scrapers that are supposed to help guide the paper out, when they wear out the catch the paper and turn them into accordions. Replace the claws, and check the heat rollers.
Panasonic...
Answered
on Jul 23, 2008
Document Feeder Jam
Paper is often guided via mylar /plastic strips within coopiers. It is possible that a certain section has been bent and is obstructing the paper path.
It is not too difficult to open the document feeder - just be careful in remembering what came from where :)
The obstruction could also be a piece of paper that was torn while removing a prior paper jam.
Panasonic...
Answered
on Jan 09, 2008
PaNaSoNiC pRinTeR inStaLlAtIoN sUpPoRt nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-866-785-37l5
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS.. CARRY ON4
Panasonic Office...
Answered
on Nov 06, 2019
