20 Most Recent
Sony VPL CS4 Multimedia Projector Questions & Answers
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
Press the "Menu" key to exit the menu system.
Read more :
http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
How to Reset Sony Projector eHow
Turn on your Sony projector after replacing the lamp.
Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
Read more :
http://www.ehow.com/how_7196165_reset-sony-projector.html
I have the Sony VPL
if your TV has video output signals for the program you are watching, then you can connect them to the projector.
otherwise you may need to get a cheap digital set top box and tune to the same tv program, and use the video output to feed the projector
My sony projector vlp-cs4 is
hi,
check the power cable first. also check the power at the wall out let. if all ok, the ur projectors smps power supply have some problem. check the same if found faulty replace it. for any assistance feel free to contact through fixya.
ok
VPL-CS4
Projector on Standby, press RESET, <<=, ==>, ENTER to reset lamp timer.
No power to Sony cs4
Ok - So i finally located the problem for the Stby lights not coming on......
Mine had the same procedure as all the other posting this - Could take up to 48 hours for the light to come on but this time only the whistling sound from the fan house on the front was present.
So i dissmounted the power supply located on a standing card at the back of the housing and found the faulty component :)
The solution for this problem is a IC in that board called IC MCZ3001DB changes this and all your problems with the projector not starting will be solved.
Sony VPL-CS4 projector
Denis, by default laptops usually output only to their own lcd panel. There must be a key combination on your laptop wich rotates output in 3 steps: lcd panel only, lcd + TV (projector), TV only.
The key combination uses a special Function key (FN) usually blue (found near left Ctrl key)with one of the numeric keys.
So, first make sure your laptop output is correct and then try input key on your projector.
