20 Most Recent Sony VPL-CS7 Multimedia Projector Questions & Answers
0answers
The display cuts off the bottom quarter of the image
you have a weird display resolution set somewhere on the laptop. The vplcs7 is relatively old. It only supports 800 x 600 (SVGA). If you are cloning your monitor, you need to set the output to the projector also to 800x600. Depending on how your laptop is configured you may need to set your laptop monitor to 800x600 while using the projector, then going back to the normal resolution when you are finished.
2/2/2018 8:21:00 PM • Sony VPL-CS7... • Answered on Feb 02, 2018
How to reset sony projector vpl-es2 without remote
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
11/27/2017 5:48:29 AM • Sony VPL-CS7... • Answered on Nov 27, 2017
I want to replace the lamp but i don't have a remote ? what should i do ?
You can replace the lamp very measly, but, there is a need to reset the lamp time. For that, you should have its remote control. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/21/2014 8:41:30 AM • Sony VPL-CS7... • Answered on Apr 21, 2014
When I turn my projector on within seconds it turns itself off.
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
4/9/2014 3:47:46 AM • Sony VPL-CS7... • Answered on Apr 09, 2014
My sony VPL-CS7 projector lamp goes of very minutes
1,if the lamp can be lit for 1minute,so the lamp is ok it seems that the lamp ballast or mother board is defective.pls check them any questions, feel free to ask me have a nice day! Jerry Lampdeng Limited
3/4/2014 7:10:08 AM • Sony VPL-CS7... • Answered on Mar 04, 2014
SONY VPL-CS7 LENS EMITS YELLOW RAYS
yo tengo el mismo problema alguien que tenga alguna solucion???
7/17/2013 1:38:13 AM • Sony VPL-CS7... • Answered on Jul 17, 2013
2answers
Someone from my work has
you shouldnt need a dvd to install the projector all you need to do is enable the external monitor interface on your laptop. User manual can be found here
http://www.aboutprojectors.com/pdf/sony-vpl-cs7-manual.pdf
6/1/2011 6:10:47 AM • Sony VPL-CS7... • Answered on Jun 01, 2011
Please replace the lamp
On your remote,push these 4 buttons in this order.
RESET < > ENTER
4/8/2011 1:28:32 PM • Sony VPL-CS7... • Answered on Apr 08, 2011
When i turn on the
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
2/11/2011 11:25:39 AM • Sony VPL-CS7... • Answered on Feb 11, 2011
0answers
2answers
With the vpl cs 7 can two computers be run off the
this manual will tell you if you can or not but with most projectors it will not show both the computers at once but you could have both pluged in and switch between computers,http://www.fixya.com/support/p201884-sony_vpl_cs7_multimedia_projector/manual-16017
7/4/2010 5:48:44 AM • Sony VPL-CS7... • Answered on Jul 04, 2010
How can we resate the lamp hurs
press key Reset,Right Arrow,Left Arrow then Enter and restart projector.Lamp hour show "0"
3/2/2010 5:14:57 PM • Sony VPL-CS7... • Answered on Mar 02, 2010
Sony VPL-CS7 Multimedia Projector Logo
28 questions posted
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
reset sony projector vpl es2 without
  • Office Equipment & Supplies
