20 Most Recent
AIGO F008 MP3 Player Questions & Answers
Mp3 players
have you tried installing your mp3's song manager? such as installation cd?
Incorrect format
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything.
-Tha Mp3 Doctor
When i switch the mp3 on its say error reformat again...........
There are two ways to format an Mp3 player - one on the computer
-Tha Mp3 Doctor
Aigo F529
I'm confused. Are you saying that you can't play files on the SD card from the computer itself? Or, the songs won't play on the mp3 player once the SD card is loaded into the mp3 player?
First, make sure the songs are in the right format - each mp3 player will only play files of a certain type. Your best bet is to only use Mp3 format files -everything else is going to give you one problem or another.
Second, there is a size limit to what type of SD card the mp3 player can read. 2GB SD cards are the absolute maximum that this player will handle, and probably only 1GB even.
Hope this helps a little.
I am a Malaysian
Obviously, something has be disconnect or shifted or broken inside the camera. I believe it has something to do with the power button, since it can charge but won't power on.
I would recommend you take the camera to a repairman because camera repairs needs professional touch because of its nature.
I wouldn't know who can repair the camera in Malaysia because I don't stay there. But I would suggest you ask a friend to direct you to a repair shop where the camera can be fixed.
Good luck.
