20 Most Recent
Aiwa HZ-WS2000 MP3 Player Questions & Answers
Uploading songs onto the Missil flashMP3 player
Hi There,
First you have to charge it up fully by plugging it into the computer with the usb cable it came with. if yo have windows 2000 or higher you don't need to install the software it came with. It takes 4 hours to fully charge. Shut your MP3 missil player off and the plug it back into the computer with the cable it came with. Microsoft window plug and play should automatically indentify the devive as a storage device. All you do from there is drop and drag your mp3 songs iinto the storage folder in your device. Enjoy your new device
Hi, I am looking to
Use Google to search for this model MP3 player on the Internet or on EBay then you can get prices from various suppliers.
Drivers required only for Win98. Other versions on Windows have drivers installed. Plug usb cord into PC and into Missil Player. Open my computer, removable disk which is the Missil player) and file where desired music is. Drag music from storage file to "removable disk in "my computer". Treat it as a hard drive copy to, delete or format. To continue playing where you left off when restarting, hold off/pause button down for 3 seconds before shutting off.
Starting up missil flash MP3 player
You can use your mp3 without the software. When you plug it in, it will ask you if you want to install drivers. Click "no" and open the player as you would a flash drive. Drag and drop your favorite tunes and it should work fine.
You will need the software for firmware upgrades, voice recording, and other advanced features, but most of the function does not depend on installing that disc.
Missil Mp3 player pmp-8308
I have no Problem with mine. Just read the manual and play around with it. Mine fast forward and rewind @ 2x, 4x, 8x, 16x, and 32x time the speed. I have no problem putting in folders in the record folder with the manufactured software it cam with. I even can hold up to 12 movies on it. The Micro sd slot holds up to 8 gb making this mp4 player a 16 gb player. All I can say play around with it more. A problem is the touch screen can be too sensitive but that is a miner problem for me. I just softly touch the screen. It can pause and stop. Hold three second to make it stop. tap fast forward to go to the next videos or movie in folder. If hold for three second the fast forward or the rewind you get the time speeds each time you hold for three second. To me it is a Good Mp4 and Mp3 player for the price I paid. With the micro sd in it making it 16 gb, I can hold 12 movies, 8,000 songs, 700 pictures, and have 9 text in the ebook: This is what I have on Mine. Just learn more by playing around more with it.
GL-15052 video errors.
You need to find and install the MISSIL SD-2801 software to convert the videos then convert those wit your GL-15052 converter, then rest asured it will work I have both that is how I made it work for me.
Have fun
Z. Brad
I cant see the mp3 files or play them in the Missil MP3.
Probably you are not putting the files in the right folder. Try using the software which came along with it to put in songs. It will help u a lot. Make sure ur system is free from virus. Also do a format to ur mp3 player and then give it a try.
Thankyou
Aiwa HZ-WS2000
I got the same problem.
First the player wasnt recognized by any computer so I was stuck with the song inside them.
So I formated the disk and all suposly was fine, when i started the player I got a messar
boot error, shutting down
The trick was that when I formated the player, it has to be in Fat 32 with 4096 bites
(to format it by the way, conect the player to the pc, go to my
computer, select the player, right click, and select format with the
spects fat32 and 4096 bytes)
Then reinstal the firmware included in the cd.
this solved my problem and im very, very happy to have my player working again. I love my player!!!.
Battery
hi ummm maybe because its not a good mp4
Missil pmp-8308 has a frozen screen
Hi There,
On the pmp 8308 Missl Mp4 there is a hole on the left side of the device. Just stick a needle into the hole to push the reset button on the inside of the device to unfreeze the device.
How to set the time and date on a missil pmp-8308
it was a struggle to find that out when i first got it,
-touch the clock symbol
-enter date...
-when you entered the date. Touch the calendar symbol, which is right below the " <-- "
-then it should ask you to put the time, once you entered the time click the clock symbol which is right below the ' <-- " then your done all set
Aiwa Z-L700 cassette player will not work but CD player is fine. Is there a simple solution please?
The complexity of the solution depends on the problem. The drive belt or pinch roller may be worn or have a hardened surface. If the tape doesn't turn at all or only very slowly in any function, verify that the tape drive motor is running and that the belt is turning the pulley(s). If the tape tends to tangle up, check the pinch roller. Sometimes cleaning the roller with a cotton swab dampened with rubbing alcohol will work, but if it's too hardened, you'll need to use rubber conditioner or replace it.
If nothing at all happens when you select the tape function, there may be an electrical problem such as a dirty contact on the function switch or a broken wire in the tape mechanism.
This is far from a comprehensive repair guide; it only covers the most common issues other than broken plastic parts. "Will not work" is too general to provide more than that. Cleaning the pinch roller and its drive pin can be done through an open cassette door; everything else most likely requires taking stuff apart, observing operation and perhaps making voltage measurements.
