20 Most Recent
Shopnbc Zeki 10.1" LCD Android 4.1 8GB Storage Wi-Fi Tablet w/ App Pack Questions & Answers
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
Zeki tablet 10.1 will not charge
not familiar with that tablet but most charging problems are either the cord or battery needs replacing. If light does not come on when on charge then you need a new cord. If light comes on and it won't hold the charge then it's time to replace your battery.
Does the zeki 10.1 tablet run Netflix
1. Connect your tablet to a wireless network.
2. Download and install the Android version of the Netflix app from the Play Store.
3. If you have a subscription to Netflix, open the app you just installed and enjoy ! Otherwise, subscribe to Netflix and then do Steps 1 and 2.
Hope this helps.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
