20 Most Recent
Funai EWF2004 20" TV Questions & Answers
I have a SV2000 TV
Try going to a store like Walmart and buying just a universal remote and try different remote codes listen in the instruction manual until you can access the menu and do a channel scan. That's really the only solution I can think of.
Tv high pitch
Hi
This is most likely a problem in the High Voltage section of the set, probably the High Voltage Transformer, this is something only a qualified technician should service due to the dangerous voltages and shock hazzards involved.
There is no way to
most universal remotes let you search through the code base by simply following the steps to enter a code then just keep pressing the channel up button instead of entering the code, just keep hitting the channel up button until it changes the channel on the tv. 9 out of 10 times this will work! GOOD LUCK!!
I have a SV2000 t.v. dvd combo also made by Funai.
is it a universal remote? Most remotes if they have dvd tv sat or vhs buttons you just hold the setup(code search) button and hold it until it blinks and stays red then hit which device you want to setup and if you dont have the code just press the channel up button after the first two steps untill it manipulates the device! and changes a channel or radio station or what knot.GOOD LUCK!!
Funai dvd recorder e3 error
THat means it is unable to record successfully.
Try cleaning the lens with compressed air in a tin, (used for cleaning).
Do Not use a cleaning disc, as that can lead to permanent damage to the lens and focus coils.
How to reset my funai TV resolution mismatch
On your remote control, press MENU.
Highlight Settings with the down arrow button, then push OK.
Press OK after highlighting Television with the down arrow button.
Select TV resolution, then click OK.
Select HD 720p, HD 1080i, or HD 1080p using the arrow buttons.
Click OK.
FUNAI
What's the question?
