20 Most Recent
1996 Ram 1500 Questions & Answers
How do i check fuel pressure on my 96 dodge ram
one way to tell if your engine is getting fuel is to turn the key but dont start it you should hear a buzz which indicates your engine is getting fuel if you dont hear the buzz you need new fuel pump. if you hear the buzz before it starts and are going only 25 check your transmission fluid make sure its not low and if its dirty change it asap it could fix your issue there, i could be wrong also but if you dont hear a buzz before you start your going to need new fuel pump and if youre doing this might as well change your fuel filter to. if it has to much dirt and is dirty you can lose pressure and your engine will run real lean.
1996 dodge 1500 intermittent headlight problem
Most likely a loose wire, or a bad earth, check all earth wires including engine to chassis strap, car must have large earth to battery from chassis and engine, and/or an engine to chassis strap sometimes a relay needs replacing, does it happen the same on low as high beam? if it's ok on low then it's likely the relay probably near the fuses, if it's the same on low, then check the switch and plugs under dash and at light bulbs, light plugs often get corrosion as do the globe tags.
Headlights go off and on intermittently
My key wount work its saying bad key
This can be caused by a bad key or a bad WIN module. You will need scan tools to correctly diagnose. An automotive locksmith may also be able to help with testing your key for proper transmission.
Dodge remote start
Something is not connected right. The alarm should not inhibit normal day to day use of your transponder key. Recheck connections and be sure no factory connections are loose.
