20 Most Recent Braun Novamat 330 Slide Projector Questions & Answers
I have a Braun Novamat
Sounds like the belt. The USA service center is 800 735-4373. Otherwise contact the service center in your country.
10/21/2011 8:08:28 PM • Braun Novamat... • Answered on Oct 21, 2011
The reverse forward feature doesn't work
To advance the slides forward just tap the advance button. To revers it hold the advance button down. If that doesn't do it it will need service.
9/15/2011 6:44:41 PM • Braun Novamat... • Answered on Sep 15, 2011
Slide advance mechanism locks up
If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
9/15/2011 6:14:13 PM • Braun Novamat... • Answered on Sep 15, 2011
Autofocus
Hi- I'm not at all familiar with this model so won't suggest a particular fix. However, in general, you may find some gear or other mechanical linkage, or perhaps a spring holding a gear in place has slipped. That caused the same symptm in some old Kodaks I know of. If you cannot figure it out AND you don't mind not having autofocus, you could disable AF. Inside you will find some sort of small light bulb. Disconnecting one lead will turn off that light and prevent AF from doing anything. If you end up taking that route, make sure you load all your slides in with the emulsion facing the same way (that's the less shiny side of the slide). This will reduce the amount of focus difference between slides.
2/20/2009 5:52:45 PM • Braun Novamat... • Answered on Feb 20, 2009
0answers
The motor struggles to turn the fan on my Braun Paximat N24 slide projector. Any ideas please?
My guess is the sleeve bearings in the fan motor need oil. I use teflon based oil.
1/5/2015 12:22:29 AM • Braun Office... • Answered on Jan 05, 2015
Seeking replacement lamp
Try Bulbman.com or Bulbs.com or the retail chain called "Batteries PLUS Bulbs". If they don't stock them, they should be able to point you toward someone who does. Good Luck !! Jim
12/4/2014 1:50:24 AM • Braun Office... • Answered on Dec 04, 2014
2answers
I require a bulb for a Braun Paximat slide
Try checking with www.bulbman.com They have an amazing assortment of lamps for projectors!
11/12/2014 8:15:00 PM • Braun Office... • Answered on Nov 12, 2014
Braun Novamat 330 Slide Projector Logo
5 questions posted
Top Braun Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Office Equipment & Supplies
Most Popular Question
autofocus
  • Office Equipment & Supplies
