20 Most Recent
Alpine CDE-7856 CD Player Questions & Answers
Turning on the SW feature
Try holding down the set up button for 2-3 seconds. Press Dn or Up to select the subwoofer mode and the band button activate/deactivate SW function.
I'm trying to install an
The red wire will be for constant power and the yellow wire will be for your accessories power. If you dont have accessories you will have to hook it up as you have said. To power the unit off, there should be a power button in the top left area of the unit. Hold that button down for a few seconds and it should turn off.
Can I hard wire an IPOD connection to a Alpine CDE
There are 1/8"(headphone cable) to rca cables available at Radio Shack, Best Buy, Walmart, etc.... If you have an open pair of RCA's female connections coming out the rear of your deck plug your rca male to 1/8" male into that then into your IPOD.
Why wont cds i make with my computer play on my
OFTEN the CD's haven't been "finalized" by the computer which is needed for many of the players. If the program offers up the option to add further songs to the CD, it is NOT finalized.
You MIGHT also try using the "music" type CD's to record on... They are more expensive but Staples sells them.
Cd won't eject
sounds like the c.d. has a paper label on it, yes? my stereo won't eject c.d.'s with paper labels,....reach in there with a pair of thin needle nose plyers and yank it out,.....good luck, cracklin joe,......
I have 2 channel amp but only one sub. how do i
is the amp "bridgable"? ou have a 2 channel amp, look a the terminals that are for the speaker output. they should have + - , + - 1 positive and 1 neagative per channel. but if you can bridge the connection it alters the power and nearly doubles the power output look to see if the output terminals have somethign like this + (+) - , + - (-). in that case you would hok the positive wire up to the left output terminal and one wire to the right output terminal.
No Subwoofer output
the connections to the amp seem to be all wrong .check the wiring again.Does your deck have a seperate sub woofer output ?If it does , just connect one sub, i repeat, just one sub,and see the output.
OR
check the GAIN control on the amp.it should be 2/3rds of the max volume of the cd player.check it is not zero!
AND
Set the amp to the L.P.F. position.
bye .happy listening.
Alpine cde-7853
hold down display button until time is blinking, about 20 - 30 seconds. to change hour press 5 button, to change minutes press 6 button. get time set then press display button again.
Setting preset channels
Here is the entire owners manual, you can print it out too.
http://vault.alpine-usa.com/products/documents/OM_CDE-7856.PDF
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
- Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
- Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
- System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
- Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
- Turn off the player and then turn it back on to see if it resolves the issue.
- Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
- If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
- Check for any visible obstructions around the disc slot and remove them if present.
- If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema:
1. **Reinicie o Aparelho:**
- Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente.
2. **Restaurar as configura??es de f?brica:**
- Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas.
3. **Verifique a vers?o do firmware:**
- Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante.
4. **Remova Dispositivos Pareados:**
- No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos.
5. **Atualiza??es de Software:**
- Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o.
6. **Contate o Suporte T?cnico:**
- Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema.
Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
