20 Most Recent Alpine CDA-9805 CD Player Questions & Answers
manual
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
8/20/2012 12:51:41 AM • Alpine CDA-9805... • Answered on Aug 20, 2012
Trying to connect ipod with
make sure volume is up on the ipod itself
3/28/2011 9:18:57 PM • Alpine CDA-9805... • Answered on Mar 28, 2011
Set clock on a alpine
Heree is how to set the time on the radio.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
11/6/2010 8:41:15 PM • Alpine CDA-9805... • Answered on Nov 06, 2010
My cda-9805 unit quit working after changing out
did ;you check all your fuses? it sounds like you may not have power going to the red (ignition) wire.
8/6/2010 4:55:19 PM • Alpine CDA-9805... • Answered on Aug 06, 2010
Intermittent power to head unit
no inline fuse? I usually just slip the wire inside the battery connector, remove connector lay wire across battery with stripped end running up the side of the battery terminal place connector down on terminal and wire, tighten connector back up.
2/22/2010 8:30:59 PM • Alpine CDA-9805... • Answered on Feb 22, 2010
2answers
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
11/30/2009 10:07:53 PM • Alpine CDA-9805... • Answered on Nov 30, 2009
2answers
What is the AUX good for
I use the Aux to plugin my Ipod, amke sure you have it set on. Then it acts as the plugin. it was originally there for XM radio or a tv.
11/30/2009 10:03:31 PM • Alpine CDA-9805... • Answered on Nov 30, 2009
Engine noise coming through speakers
Make sure you are using resistor plugs, have a proper ground in the system, have good plug wires and are connected to the correct power line.
10/7/2009 5:01:00 PM • Alpine CDA-9805... • Answered on Oct 07, 2009
Engine nosie
Hi there
Two common things you can try is to a, Run the speaker wires away from any power wires in your car,
Secondly head to an auto store or auto electrician and buy a couple of ignition noise suppressors. Whiel youre there ask them to qucikly show you how to fit them up as they are all diffferent and this should solve the problem.
However if you do this and theres still noise try changing your spark plugs to resistor type plugs If they arent allready and make sure that you have you stereo wired up correclty with sufficent eath wires and positive in wires.
Also it helps to check that the eathing wire from the battery to the car chasis is clean from corrosion and is sufficent size for the output of your stereo.
Hope this helps you out.
Cheers
Steve
4/3/2009 1:02:44 PM • Alpine CDA-9805... • Answered on Apr 03, 2009
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
11/6/2008 5:59:56 PM • Alpine CDA-9805... • Answered on Nov 06, 2008
Alpine CDA-9805 head unit - frequency hops
make sure no switches are jammed on radio or radio face.Liquid spillage and or intermittent switches on tunning section can also cause this.
11/29/2007 11:45:53 PM • Alpine CDA-9805... • Answered on Nov 29, 2007
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
  1. Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
  2. Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
  3. System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
  4. Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
  • Turn off the player and then turn it back on to see if it resolves the issue.
  • Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
  • If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
  • Check for any visible obstructions around the disc slot and remove them if present.
  • If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
3/2/2024 3:22:33 PM • Alpine Car Audio... • Answered on Mar 02, 2024
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema: 1. **Reinicie o Aparelho:** - Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente. 2. **Restaurar as configura??es de f?brica:** - Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas. 3. **Verifique a vers?o do firmware:** - Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante. 4. **Remova Dispositivos Pareados:** - No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos. 5. **Atualiza??es de Software:** - Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o. 6. **Contate o Suporte T?cnico:** - Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema. Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
2/16/2024 6:59:12 PM • Alpine Car Audio... • Answered on Feb 16, 2024
Alpine CDA-9805 CD Player Logo
23 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
set clock alpine
  • Car Audio & Video
