20 Most Recent Alpine CDM-9821 CD Player Questions & Answers
How to wire aftermarket cd player to ba falcon
Get the facia kit, Acc+ and Gnd are tapped off the cigarette lighter Batt+ is found in the BLUE plug behind the interior fuse box. Speakers FL, RL, RR are found behind the glove box and the FR speaker in the drivers kick panel. There are also other precautions to take when installing it to avoid frying the ICC computer which controls all the interior. When attaching speaker wires ensure you connect the correct side behind the glove box connect the left side of the cut and in the drivers kick panel connect the right side of the cut. Speaker wire colours are Grey FR, Orange FL, Pink RR & Blue RL. All speaker wires are twisted together. Influential Customs
10/31/2018 6:02:08 AM • Alpine CDM-9821... • Answered on Oct 31, 2018
3answers
Aux input
1.Press and hold the " F " button for 3 seconds
2.Turn the big volume knob to the right till you get to " AUX "
3.Than press the " Band " button - It will say "on"
4.Exit out. Press "Source" on Radio till it says "AUX "
** You will now hear your Auxilary input
LCW Automotive Corp
www.lcwlimo.com
2/22/2016 8:46:44 AM • Alpine CDM-9821... • Answered on Feb 22, 2016
Volume button cannot adjust
Sounds broken but clean the connectors of the faceplate. Did the sound work before? If it did time to order a new radio.
1/22/2015 5:26:18 AM • Alpine CDM-9821... • Answered on Jan 22, 2015
How do you tighten volume knob
Some older units have a small screw in the side of the knob. Use the proper tool to tighten that screw. If there is no screw and it uses a flat metal spring use a dental tool to bend the spring gently back into place. If this is all plastic with no adjustment consider using silicone sealer. A small dab will keep it on and allow you to remove it later if needed.
8/28/2014 3:44:45 PM • Alpine CDM-9821... • Answered on Aug 28, 2014
Stuck in cd player mode
I had the same head unit. Did the same thing i just unplugged it and waited a little bit plugged it back in. Clean off the prongs where the face plate plugs into the deck too. worked for me. hope this helps
5/19/2014 12:07:01 PM • Alpine CDM-9821... • Answered on May 19, 2014
0answers
I want to know how
Assuming you have wiring diagram or labeled on deck, try here for wiring on Van.
http://www.the12volt.com/
8/17/2011 12:06:44 AM • Alpine CDM-9821... • Answered on Aug 17, 2011
My volume knob is not working properly. where can
you can try pacparts.com.
7/20/2011 5:02:58 PM • Alpine CDM-9821... • Answered on Jul 20, 2011
Cdm 9823 free manual
4/23/2011 6:18:51 PM • Alpine CDM-9821... • Answered on Apr 23, 2011
Alpine Car Radio - how to change time
set time on alpine stereo model CDM 9821
11/18/2010 6:40:18 PM • Alpine CDM-9821... • Answered on Nov 18, 2010
Why is there no sound when playing cd on the
check the speaker connections or the speakers
10/10/2010 4:22:40 AM • Alpine CDM-9821... • Answered on Oct 10, 2010
Display lights not working.
It could be that the contacts are slightly oxidized, and need cleaning, or are just loose on the inside. You can take electrical contact cleaner and clean them. You might have to open up the unit to access interior contacts. It could also be a power supply issue to the display board, in which case, the unit would have to be troubleshot to verify the problem.
Here is a user's guide, in case you don't have one:
http://www.retrevo.com/support/Alpine-CDM-9823-Car-Receivers-manual/id/23223dj390/t/2/
Good luck, and hope this helps.
9/22/2010 10:20:55 AM • Alpine CDM-9821... • Answered on Sep 22, 2010
The cd is stuck and
try resetting the radio.
8/12/2010 4:57:09 PM • Alpine CDM-9821... • Answered on Aug 12, 2010
When I try to tune in the station it only stops on
radio stations on FM are only odd numbers...
such as 102.1 102.3 102.5 102.7 102.9 103.1 103.3 103.5 etc etc. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
8/8/2010 5:43:32 AM • Alpine CDM-9821... • Answered on Aug 08, 2010
Rear speakers just stopped working. Turned fader
try switching the front speakers to the rear speakers it it still doesn't work then you have a problem with your unit's power amp.
6/10/2010 11:35:38 PM • Alpine CDM-9821... • Answered on Jun 10, 2010
A cd is stuck how do I get it out
try disconnecting power to the radio for a few minutes.
6/10/2010 4:46:28 PM • Alpine CDM-9821... • Answered on Jun 10, 2010
Alpine CDM-9821 CD Player Logo
64 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
want know
  • Car Audio & Video
