20 Most Recent Kodak C183 Digital Camera Questions & Answers
0answers
Turn volume
Be the first to answer 11/18/2013 3:31:37 AM • Kodak C183... • Posted on Nov 18, 2013Be the first to answer
What driver do i need to install for my kodak c183
To use on a windows 7 or8 just plug it up if it does not reconise the camera go to Kodak and down load the newest driver you may have to download kodaks picture manager > I personally will not use a Kodak the drivers have caused problems just inter the camera info in the site it will give you a list of downloads use newest software
2/7/2013 5:40:24 AM • Kodak C183... • Answered on Feb 07, 2013
C 183 will not transfer pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
12/13/2012 2:47:53 AM • Kodak C183... • Answered on Dec 13, 2012
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
8/1/2012 10:57:06 PM • Kodak C183... • Answered on Aug 01, 2012
Pictures will not transfer to
What model of Kodak?
10/29/2011 1:30:17 AM • Kodak C183... • Answered on Oct 29, 2011
I want to change the
Don't go to the setup menu. The "Color Mode" option is in the Capture/Video menu, not the Setup menu.
8/31/2011 7:46:23 PM • Kodak C183... • Answered on Aug 31, 2011
How do I reset the
I must advise against doing that. If you do, every time you try to download pics to the computer, it will think you've already downloaded pics with those numbers and either refuse to do it or it will erase the previous pics to make room for the new ones.
8/17/2011 11:23:44 PM • Kodak C183... • Answered on Aug 17, 2011
Download pictures from camera card
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
8/2/2011 4:31:34 PM • Kodak C183... • Answered on Aug 02, 2011
Users instructions for C183
You can download and print the instruction manual in PDF format by clicking this link.
http://resources.kodak.com/support/pdf/en/manuals/urg01133/C183_xUG_GLB_en.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
7/4/2011 7:17:03 PM • Kodak C183... • Answered on Jul 04, 2011
Lens obstructed and goes off.
Unfortunately, many cameras that fall prey to lens error problems (Lens obstructed on Kodak's) can only be corrected by professional repair. But, here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
7/3/2011 8:21:51 PM • Kodak C183... • Answered on Jul 03, 2011
I have a new Kodak
Try NOT connecting your camera to your computer.
7/1/2011 9:07:57 PM • Kodak C183... • Answered on Jul 01, 2011
I have a Kodak easyshare
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
7/1/2011 1:35:10 PM • Kodak C183... • Answered on Jul 01, 2011
I deleted my pictures by
Here is a tip that I wrote about how you might be able to recover things from a memory card or camera
How toRecover Deleted, Corrupt, or Unreadable Files from Memory Card
heatman101
6/27/2011 12:02:58 PM • Kodak C183... • Answered on Jun 27, 2011
How do you change the
Select "Color Mode" from the Setup menu.
http://resources.kodak.com/support/shtml/en/manuals/urg01133/urg01133c5s1.shtml
6/23/2011 9:03:42 PM • Kodak C183... • Answered on Jun 23, 2011
How can i change the
According with the user manual checl "Color Mode" settigns...
Hope this helps (remember to rate and comment this answer).
5/26/2011 3:26:14 PM • Kodak C183... • Answered on May 26, 2011
How do i take a
Press the MENU button. Use cursor-left/right to select the Capture tab. Use cursor-up/down to select "Color Mode" and press the OK button. Make your choice.
4/14/2011 6:13:55 PM • Kodak C183... • Answered on Apr 14, 2011
Downloading
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/12/2011 5:39:55 PM • Kodak C183... • Answered on Apr 12, 2011
Will theC183 time/date stamp on
Yes there is option in the menu. just enable the feature to get it.
4/2/2011 2:57:33 PM • Kodak C183... • Answered on Apr 02, 2011
Camera won't come on when I connect to my computer
Make sure Batteries are in the camera and are functioning properly.Make sure camera is turned on and the cable is plugged into the correct ports on your computer. If this does not work, please refer to this Transferring pictures to your computer
2/28/2011 4:35:30 PM • Kodak C183... • Answered on Feb 28, 2011
I can't seem to download , or view photos taken
Download Kodak Software from here http://support.en.kodak.com/app/answers/list/p/4,48/c/890/src/gocamerasw/selected/true by selecting your operating system. Install it by following the on screen instructions.
2/28/2011 3:57:22 PM • Kodak C183... • Answered on Feb 28, 2011
Kodak C183 Digital Camera Logo
38 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
Kodak Cameras
  • Kodak Cameras
Most Popular Question
new kodak
  • Cameras
