20 Most Recent
AVG Anti-Virus & Firewall 9.0 (2 Computers) (AVG9AVFW2) Questions & Answers
I CANT REMOVE THE VIRUS IN MY LAPTOP
If you cant remove the virus you have got, its often because your drive has been infected to a degree where qiping it for virus's is futile.
If thats the case, format your drive by booting your pc up with a windows install dvd in the drive, selecting the option to format C-drive before installing new operating system on the unit.
Most likely you Boot-section of your harddrive has been infected and therefore, everytime you boot your pc the virus loads as the first thing during start up of windows and drivers and so forth.
Cant run avg antivirus software
You might have another antivirus interfering with AVG Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart you might only tick in one box to automatically fix files
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then reinstall your copy of AVGHope this helps
Remove my pc virus
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Reboot the computer
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentialsHope this helps.
Computer has a tdss virus
I would just format the computer and put a new operating system on it. Do you have the installation CD for your computer ? Seems like you have a nasty virus, I would format all my computers, better safe than sorry, you could battle this thing out for years or just go hardcore with it.Good luckChristopher
No license key for avg anti virus 2012
Usually for those AVG products purchased from a reseller or a retailer it would only have some sort of a temporary license number that can be converted into Full license once the user register the subscription on AVG website and Activate the product. If this product came with a box, look for something that says SALES NUMBER, this would serve are your temporary license and can be use during installation. After that, register your product @ http://www.avg.com/us-en/registration.
My AVG can not uninstall, what should i do so that
Boot in Safe Mode and do the uninstall from there - in normal mode the autoprotection is active and prevents all attempts to change the files of the program. and you can't disable that without extensive modifications of the settings . In Safe Mode the program is inactive so the autoprotection is off.
I have Real VNC (Personal
First you can try by disable AVG temporarily to see if you can access both at the same time. If you can, then we need to focus on AVG setting. However, I think the issue is with port forwarding in router. It is because you can access one but not both, that means port 5900 is always good in AVG. Just try disable AVG to see first
Also make sure that you have port 5900 open as exception list on personal firewall on those 2 pcs.
Second, you want to make sure port forwarding is good in router
Log on Linksys wrt54g, go to applications and gaming, and port range forward make sure you have 2 (two) entries in there (one for each PCs) it requires static IP of each PC in there and make sure they are enabled.
Let me know and we can continue.
Thanks
What is Free Installation Process for AVG Antivirus?
If you are looking best antivirus software for your device then AVG is a right choice. The antivirus is important software for desktop, laptop, and other devices.
This software helps to protect the important data from the malware, spyware, virus, and others.
There is the wide range of the anti-virus software available in the market but AVG has reputed name. It is reliable antivirus product that suits your budget and requirements.
AVG offers the first-class support services to their customers.
If anyone facing technical problems in the AVG antivirus software then you can call on the AVG Technical Support Number and get the effective solution for fixing the AVG problem.
We have the trained technician in our customer support team so they offer the quick solution to our valuable customer.
Our team comes with the knowledge to guide if the users need any technical support from the antivirus upgrade, UN-installation, installation, and others.
Have the customer support number to the users and get the right advice.
We provide the huge range of the AVG support service such as customer support number, technical support service, live chat support, toll-free support number, email support number, and other services.
The users can get the right solution by using the AVG support number. Our experts have the knowledge to handle any kind of issues in the AVG software.
We offer the support for AVG troubleshoot whether the issue is related to the installation, configuration, and others. The users will get the remote access to the device with their permission.
The experts will provide the information on how to fix the problems and run the AVG antivirus software effectively that the malware and spyware can be removed.
Use AVG tech support number AVG technical support number helps to deliver the verified solution that facilitates the secure network around the globe.
The PC users store all their personal information and documents in the device. This antivirus software provides assists to protect the users.
Dial the AVG Help and Support Number for contacting the technicians directly and get instant solution for fixing the antivirus problems.
We use the remote control system to resolve the issues from the office. Our experts have the skill to fix the technical glitches in the short time.
The AVG support phone number is launched officially on the website for the user convenience to deliver the suggestion instantly
On the off chance if you are still getting troubles then call Antivirus customer service number +44 203 880 7918 (Toll- free). Resource link: https://www.advisorexpert.co.uk/antivirus-support-phone-number/
