20 Most Recent Microsoft Windows Vista Home Premium OEM Questions & Answers
2answers
Download windows vista
Just stay away from Vista. Go for Winodws 7 Pro or Windows 8.1
1/20/2015 10:38:55 PM • Microsoft... • Answered on Jan 20, 2015
Why i can not send e-mail to my friends?
Sounds like you might have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira.You should be in pretty good shape if you run and install all of these programs...
7/20/2012 7:36:19 AM • Microsoft... • Answered on Jul 20, 2012
Bypass windows password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode. Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
Hope it helps
6/26/2012 4:08:05 AM • Microsoft... • Answered on Jun 26, 2012
Daughter forgot password at login screen, tried to boot into safe mode with command prompt but did not have prompt
Smartkey Windows Password Recovery is an easy-to-use tool designed for resetting Windows password or domain password on any Windows system. If you have forgotten your password, or are locked out, or you do not have access to the password of the system. It is the most effective product on the market. with a Graphical background and it is the easiest solution for Home Users and the overall Best for Businesses. You only need to boot from Smartkey Windows Password Recovery CD/DVD, and reset forgotten vista password to Blank . Then you can get back into your system with blank password. No need to call a technician, no need to re-install anything, and you certainly don't need to reformat.
6/25/2012 3:58:54 AM • Microsoft... • Answered on Jun 25, 2012
Free download microsoft
if its the serial key you need
bgq7m-kvjyq-ftdc3-bgryx-tp32chope it helps
4/14/2012 11:05:49 PM • Microsoft... • Answered on Apr 14, 2012
On a monthly hardware diagnostics check,a surface scan failed the test.Is there a free tool to fix this problem avbailable to download?
This error often means that a physical spot on the hard drive has failed. Additional spots are likely to fail soon. Back up your data (build a recovery disc set if you haven't done so) and then get a new hard drive to replace the old one as soon as possible. (You may want to get drive cloning software - which will copy even the hidden recovery partition to your new drive.) Rarely, the error means that a file is corrupted on the disc. Programs like SpinRite, http://www.grc.com/intro.htm , or HDD Regenerator, http://www.dposoft.net/ , may solve the problem. I'd still plan to invest in a new hard drive. If your computer is still under warranty (with an extended warranty since you list Vista as the OS), contact the manufacturer about the problem.I wish that I had better news for you. Cindy Wells (Drives will fail. This scan is meant to let you save your data before the drive completely dies. Since you have Vista, the hard drive was assembled at least 3 years ago and could be more than 6 years old.)
4/3/2012 4:46:51 AM • Microsoft... • Answered on Apr 03, 2012
Mail sent in windows mail is not put in sent
Hi, just set your setting by default and if your problem did not resolve read the following helpful article.
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-with-Windows-Mail
Good Luck
2/5/2011 4:36:22 AM • Microsoft... • Answered on Feb 05, 2011
3answers
Jvc everio live stream
That's it, follow of what the app required.
9/4/2021 2:17:13 PM • Microsoft VISTA... • Answered on Sep 04, 2021
Product id 89572-OEM-7332166-00019 what is vista home basic activation key ?
try calling the registration centre, they are very helpful and may well solve your problem but you ned the correct number for your OS/ To start the Product Activation Wizard, follow these steps:
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg .
  2. Right-click Computer.
  3. Select Properties.
  4. At the bottom of the window, click Activate Windows.
In the Product Activation Wizard, follow these steps:
  1. Click Use the automated phone system to activate.
  2. Click the drop-down menu, select the location that is nearest to you, and then click Next.
  3. The Product Activation Center telephone number is displayed at the top of the window.
6/14/2019 2:41:54 AM • Microsoft VISTA... • Answered on Jun 14, 2019
2answers
Checksum
This may help. If you can't identify the file or program, then use MSConfg. Go to Start > Search. Type MSConfig. Go to the startup tab and disable as many items as possible. Not to worry, the apps are still there and critical items will load anyways. Plus this will make you pc load and run faster.
4/25/2019 2:43:06 PM • Microsoft VISTA... • Answered on Apr 25, 2019
3answers
My brand New Asus laptop keeps dropping off wireless network
try it on another wireless connection and see how it works. Belkin routers are usually not the best, that's why they are so cheap
If the prob persist on another wireless network than contact ASUS technical support
10/4/2018 5:37:30 AM • Microsoft VISTA... • Answered on Oct 04, 2018
0answers
Youtube
On Internet Explorer click on tools choose popup blocker make sure the top line says turn on popup blocker then click on popup blocker settings and tighten up the security. Terry
12/27/2016 8:13:39 PM • Microsoft VISTA... • Answered on Dec 27, 2016
5answers
I need the product key of windows vista starter?
Supplying product keys for Microsoft products without paying for them is theft and piracy, both of which can create issues for the fixya website and the good things we do here. Please do not ask for keys here. Also members who supply such keys are violating the terms of use issued by fixya, and can have their accounts terminated. Yes they can come back with a different user id and email address, but they are jerks, and don't care about honesty and integrity. most computers have keys on them, usually have a COA sticker somewhere on the case. MS Windows (ALL versions) and Office (Word, Outlook, Powerpoint, Publisher) are NOT free, and keys should be purchased.
10/8/2016 8:13:22 AM • Microsoft VISTA... • Answered on Oct 08, 2016
Video card ati radeon hd 3200
http://support.amd.com/en-us/download/windows-legacy I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
5/15/2016 3:28:58 PM • Microsoft VISTA... • Answered on May 15, 2016
Iconvert 593715 vista driver
5/15/2016 3:08:24 PM • Microsoft VISTA... • Answered on May 15, 2016
Screen is upside down
Check it out.Ctrl + Alt + Arrow Key, shortcut rotates the display in 90 degree increments.** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
2/4/2016 7:00:21 PM • Microsoft VISTA... • Answered on Feb 04, 2016
Error C:\PROGRA~2\04D51FSE.cpp What does it do?
What are you actually doing when you get this error? Could be a printer issue than a PC issue?
7/16/2015 12:47:45 AM • Microsoft VISTA... • Answered on Jul 16, 2015
3answers
Uninstall ask
to remove ask toolbar .double click my computer.you will now see your c drive, at the top of the page you will see uninstall or change programs,click this then you will see a list of programs ,find ask toolbar in list click on it and click on uninstall and follow directions. dt
4/5/2015 7:11:52 PM • Microsoft VISTA... • Answered on Apr 05, 2015
I cant get my yahoo email to load, the message says it redirects, and the redirect goes nowhere
First try clearing your browser cache & cookies The link will have you pick your browser and show you how. Clear your browser cache and cookies
3/31/2015 8:16:49 PM • Microsoft VISTA... • Answered on Mar 31, 2015
Microsoft Windows Vista Home Premium OEM Logo
11 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VISTA Microsoft
  • VISTA Microsoft
Most Popular Question
not send e mail friends
  • Computers & Internet
