20 Most Recent Panasonic SC-HC30 Audio Shelf System Questions & Answers
3answers
I HAVE A SC-HC30DB SYSTEM
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
2/18/2023 5:33:11 PM • Panasonic... • Answered on Feb 18, 2023
The door won't open and the screen says illegal open
try sliding the door by hand to the right. If you can slide if, lift up on the left side while sliding it all the way to the right and the doot should slide off. Then try sliding it back on. One of the door switches is probably out of place and just needs to be realigned.
11/7/2013 1:36:36 PM • Panasonic... • Answered on Nov 07, 2013
0answers
DAB preset is stuck on chanel 1. Machine will not
Have you tried pressing the play mode button to change from preset to station list which will allow you to view all stations available.Nathan.
7/24/2013 11:10:25 PM • Panasonic... • Answered on Jul 24, 2013
Panasonic sc-hc3db
I researched this problem for far too long and have learned the following: The UK version of the product has a fuse in the power cord plug end. The item has three typical problems: failure of IC chip, and/or one or two diodes. Unless you are good with a soldering pencil and have some skill, it's best to make a set of speakers from those on the unit and junk the rest of it. Otherwise, it's not worth repairing or salvaging. Remember the negative terminal on speakers made be shared and is the furtherest ring out when joining a stereo mini plug to two speakers. This brand of docks usually fails due to heat dissipation problems as there is no room inside them to keep things cool and Mashushita didn't put a fan in there.
6/19/2013 4:43:51 AM • Panasonic... • Answered on Jun 19, 2013
0answers
REMOTE NOT WORKING
Put new batterys in it.
10/27/2012 8:54:07 PM • Panasonic... • Answered on Oct 27, 2012
0answers
0answers
0answers
Door will not open. Cd and i-pod stuck inside!
This has a powered door, is there power in the unit? If not then the cord or connection could be at fault, try moving or pushing on the cord. There may also be an internal fuse and the unit will need to be disassembled.
12/7/2011 12:48:17 PM • Panasonic... • Answered on Dec 07, 2011
I have a panasonic sc-hc30
Nope, they use 100V. You'll need a step-up transformer.
http://en.wikipedia.org/wiki/Mains_electricity
4/13/2011 10:36:09 PM • Panasonic... • Answered on Apr 13, 2011
Ihave lost my users instructions for my system and
Here is a link for a manual that I found online. I hope it helps!
http://static.highspeedbackbone.net/pdf/Panasonic%20SCHC30%20Manual.PDF
3/2/2011 2:49:53 PM • Panasonic... • Answered on Mar 02, 2011
How to rebuild, step by step, CD Changer Mechanism for Panasonic SA-AK20?
The nearest you will get is the service manual. Dowmload the service manual and follow the dissasambly and reassambly instructions to the letter, otherwise it will not work correctly and the timing will be out. https://elektrotanya.com/panasonic_sa-ak20.pdf/download.html
4/1/2024 8:34:15 PM • Panasonic Audio... • Answered on Apr 01, 2024
Panasonic SC-HC30 Audio Shelf System Logo
Popular Tags
30 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
door open screen says illegal open
  • Audio Players & Recorders
