20 Most Recent
Dell Latitude 2110 Notebook Questions & Answers
How can I unlock padlock with 9 in middle?
Karen Crain,
The padlock with the number 9 turns on when the numeric keyboard is enabled.Click the numlock key on the keyboard and it should go off.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
How to integrate a webcam on to Dell latitude 2110
Hi Mamadi Amadou,
Dell Latitude 2110 has an inbuilt webcam which is automatically activated. Please explain more about the issue then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Bios
Dell BIOS advanced features are locked. However, please let me know what you are trying to do then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
My dell lattitude 2110 isn't charging while plugged in
It is unfortunate that the computer is not being charged. You may want to try following the below steps which might help:
(1)Try using a known good AC Adaptor and check if the same issue happens.
(2)Try wiggling the AC Adaptor cord to see if that makes a difference.
(3)Check if the AC Adaptor is getting detected (Like a 60W or 90W) in BIOS (F2 at startup).
(4)Hover the mouse over the Battery on the status bar and see if there is any error message like Not connected or Plugged in not charging, etc appears.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell 2110 loaded all drivers, get pci device error
Device drivers are commonly the issues we run into on the PC itself. Just when all is right where you want it, down comes the issue. I got tired of this every time I format someones system. I found that
Regtool helped solve all my driver issues. Give it a try. Hope this advice helps all.
Network controller, PCI Device and
go to support.dell.com enter your 'Service tag'
you will be taken to a page with the relevant drivers for your laptop
you need the chipset drivers
How to fix my dell E4310 from freezing while im using it?
There are a number of reasons that the unit could be freezing up.
- Corrupted file(s)
- Low available disk space
- Viruses and/or malware
- Too many add-ons/toolbars/etc.
- Heat build-up
Number one is the hardest to find. So start with #2. The computer needs free hard drive space to operate. If the disk is nearly full or is very fragmented, this can slow the machine to a crawl. Check for available space and if there is plenty (20GB or more), then check for fragmentation under administrative tools. If the defragmentation tool recommends optimization, allow it to perform it and see if that helps.
For viruses and possible malware, run your virus scanner. It is always a good idea to get a second opinion on such things. Malwarebytes is a free malware scanner that works very well to find adware and some things that many antivirus programs fail to detect.
Many user feel that they have to have every bell and whistle. I've seen some browsers with 7-10 different toolbar add-ons. These almost always come with some adware and always slow down the browser. Uninstall all but the most essential toolbars for the best performance. Heat is a slayer of machines. Laptops are very susceptible to heat issue since they are often placed on beds, sofas, carpets, and yes, even laptop. Many of these units draw cooling air from the bottom and exhaust it to the side. Even those that draw air from the rear and exhaust to the side will often intake large amounts of dust, grit, and lint. These can partially or completely clog the heat sink unit and cause heat buildup of the processor. This will cause the processor to work slower and can actually cause it to thermally lockup, resulting in the need to reboot. Many units can be accessed to clean with a removable cover on the bottom; others may need to be serviced by a technician to clean.
My latitude will not power up. I have a good power
no PC told , at all, model not told
ok generic mode.
1: huge battery inside is bad, shorted remove it , even for ever.
2: run on AC power only now.
3: push power button 10 full seconds release, ,runs now?
4: no, remove all USB devices now. run now?
5: no, coin cell battery dead, , replace it , run nolw
6: no. strip the PC down to find the shorted model.
lap-strip-101
https://www.pcdied.com/Dead_screens/dead-LT.html
Can you hard wire power to laptop?
NO
if you do, a noob will blow it to kingdom come. as in letting the smoke out.
the power-pack does 3 things
it has the correct DC voltage and wattages
and #2 prevents fire when the PC fails and things short inside.
and prevents huge damaging surges landing inside the PC
buy used power pack off fleabay and win.
i bet I'd mow one lawn and and buy one
