User passwords: Power on BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords: Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password." Client Security Solution
Hi ,Ok , lets go to the control panel and there you will see user accounts , click on that icon and on the and you will see a list of things you can do . on the left side you'll see create and reset password , click on that link and your set ...........Good Luck Roy
BIOS passwords can be reset or removed in two ways:1. using software 2. using hardware.I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.You can download it here:http://www.syschat.com/download120.html&act=downCmosPwd - Cmos password recovery toolshttp://majorgeeks.com/CmosPwd_d239.htmlYou will need to create a bootable Dos, or Linux or NT cd in order to run them.Good Luck!
Are you referring to the Serial # when you say product #? If you do, for this certain unit A310 you will find it at the back of the system on a white rectangular sticker. Look for S/N. Serial # starts with 2 letters followed by set of numbers.
Hi i_shaw1,
I see you want info regarding the Lenovo A310 all in on e desktop, you can go to lenovo.com/psref then click user guide and manuals
or you can go directly to this lenovo link http://consumersupport.lenovo.com/us/en/UserGuide/Guide.html
Note: that if you system is still under warranty that it is advisable to call lenovo for proper assistance on the installation of your additional ram, if ever anything that may get damaged on the mcine under the warrany period will not be covered by the base warranty that your system mayhave unless you have an accidental damage warranty for your Ideacentre which is not applicable for Desktop and all in one systems,
you can call 18774536686 for Lenovo Ideacentre support.
I hope that this will be helpful. thanks and be careful installing your RAM ^_^
Disconnect all power sources, including the battery. Open the laptop and remove the CMOS battery (the little round silver thing). Hold the power button to drain any residual charge for 10 seconds. Boot the computer without the CMOS battery inserted. it should say password disabled. Reassemble the computer and you're done!
Check the Power Adapter and Outlet:
Ensure that the AC power adapter is securely connected to both your laptop and a functional power outlet.
If your laptop has an AC power indicator light, make sure it's illuminated. If not, try a different wall outlet (avoid using a power bar) .
Battery Charge Stops at 60%:
If your battery charge stops at 55%-60% and shows a "plugged in, not charging" message, it might be due to a power management setting.
Some Lenovo laptops have a feature that limits battery charging to extend battery life. To disable this:
For models with Lenovo Energy Management, Lenovo Power Manager, OneKey Optimizer, Lenovo Settings, or Lenovo Vantage:
Check if "Conservation Mode" is turned on. If so, turn it off.
If the issue persists, try updating your laptop's BIOS:
Go to the Lenovo support website, download the latest BIOS for your model, and install it.
Reboot your PC and check if the problem is resolved.
Hard Reset:
Sometimes a hard reset can help resolve charging issues:
Shut down your computer.
Remove the battery (if detachable).
Hold down the power button for 30 seconds (with the battery removed).
Reattach the battery, plug in the AC adapter, and turn on the computer. The battery should start charging .
If these steps don't solve the problem, there might be other causes.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON.
You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad.
On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon.
If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active,
nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it.
Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS.
How to Enable Boot device List F12 Option
The following example shows a system that has an option to enable or disable the Boot device List F12 Option.
Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
It is very simple.
Just press window key and then press PrintScreen key simultaneously.
OR you just press PrintScreen key And then open paint Then press ctrl+v it will paste your screenshot.
and then save it.
Removal steps of keyboardLoosen the screw to the unlocked position to unlock the keyboard frame. Turn over the computer. To reveal the screw heads beneath the frame, use the flat-head screwdriver to slide the keyboard forward by 2.5 mm (0.1 inch). Use the cross-head screwdriver to loosen the screws.
