20 Most Recent
Coby TF-DVD1540 15 in. TV/DVD Combo Questions & Answers
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Shows hdmi but not sure what channel
If it has a input for HDMI you will have to access that via the input or source feature on the remote or in the main menu---it is not on a channel.
Coby TV/DVD Combo
my dvd 's will not go into slot. Dvd says it is closed and no dvd. I have unplugged tv, opened and closed dvd and it will not open. What do I do?
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
- 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
- Standard 4:3 aspect ratio, native 1,024 x 768 resolution
- Plays DVD, CD and recordable MP3 music CD-R/CD-RW
- Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
- Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
- Brand Name: Coby
- Model: TFDVD-1540
- Display Technology: TFT active matrix
- Display Size: 15 inches
- Image Aspect Ratio: 4:3
- is_hdtv_compatible: N
- speakers_included_description: 2 speakers
Channels above 10
maybe s similar to TF-DVD1540.
first press "-/--" (choice for one or two digits), then press the number or two numbers.
Coby TF-DVD1540
Yes, use a VGA Cable and conect it. just select source to pc.
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you.
If you have the battery details you might be able to get one online.
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps:
Turn on the device you want to program.
Press and hold the Setup button on your remote until the LED light turns on.
Press the device button (TV, DVD, CBL, etc.) for the device you want to program.
Press the CH+ or CH- button repeatedly until the device turns off.
Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully.
Otherwise, you need to search for the manual for the remote.
Coby RC-028 under-the-counter television. on local channel 5 the audio is both English and Spanish. How do I turn off the Spanish portion?
If you are hearing both English and Spanish audio on local channel 5 on your Coby RC-028 under-the-counter television, you may need to adjust the language settings. Here are some steps you can try:
- Press the "Menu" button on the remote control.
- Use the arrow buttons to navigate to the "Audio" or "Language" menu.
- Look for an option called "Secondary Audio" or "SAP" (Secondary Audio Program). This option controls the language of the audio.
- If the "SAP" option is set to "Spanish," select the option to change it to "English" or "Off" (depending on your preferences).
- If there is no "SAP" option, look for a language setting or a similar option that may control the audio language.
- Save the changes and exit the menu.
- Test the TV to see if the language has been changed.
If these steps do not resolve the issue, consult the user manual for your Coby RC-028 or contact the manufacturer's customer support for further assistance.
