20 Most Recent Coby TVDVD2050 20 in. TV/DVD Combo Questions & Answers
Remote control code
0142 or 0126?
8/18/2018 5:46:05 AM • Coby TVDVD2050... • Answered on Aug 18, 2018
2answers
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
4/27/2017 9:02:12 AM • Coby TVDVD2050... • Answered on Apr 27, 2017
I lost my remote and need a remote code for a universal remote
To get the codes for your TV
Please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Select the remote control model,Device and Brand,It wil give you the code.
Thanx
3/18/2016 9:26:08 PM • Coby TVDVD2050... • Answered on Mar 18, 2016
Why dont the green light on my Coby TV dose nott come on
Your question need more detail. Blue color on that is no signal, or unplug the power cord for reset, good luck.
6/27/2014 6:00:28 AM • Coby TVDVD2050... • Answered on Jun 27, 2014
Sound from anything but cable?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
7/11/2013 9:21:09 PM • Coby TVDVD2050... • Answered on Jul 11, 2013
My coby tv started changing
If the set was changing color it indicates a picture tube problem, plus you also have a shutdown problem, probably due to the picture tube loading down the circuitry, far cheaper to replace the combo tv.
4/30/2011 4:05:56 AM • Coby TVDVD2050... • Answered on Apr 30, 2011
0answers
Tv dvc combo remote codes coby tv
hi! i have here a two codes for your coby tv 1460, 2380. just try them hope this helps! goodluck!
6/6/2010 12:12:23 PM • Coby TVDVD2050... • Answered on Jun 06, 2010
2answers
Coby tv/dvd will not power
for repair
1/5/2010 5:15:12 PM • Coby TVDVD2050... • Answered on Jan 05, 2010
Conneced cable via coax cable and tv says no
you need to tune tv in
12/4/2009 11:52:19 PM • Coby TVDVD2050... • Answered on Dec 04, 2009
No Cablevision remote code for Coby TV
Try 1548 or 11548.
9/10/2009 9:37:27 PM • Coby TVDVD2050... • Answered on Sep 10, 2009
Blue green line
I have a tv coby 1360 , now it have a blue screes with red locked. Please help ......What can I do it...
regards
tamara
5/10/2009 1:51:07 AM • Coby TVDVD2050... • Answered on May 10, 2009
2answers
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you. If you have the battery details you might be able to get one online.
2/6/2024 10:44:52 AM • Coby Televison &... • Answered on Feb 06, 2024
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps: Turn on the device you want to program. Press and hold the Setup button on your remote until the LED light turns on. Press the device button (TV, DVD, CBL, etc.) for the device you want to program. Press the CH+ or CH- button repeatedly until the device turns off. Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully. Otherwise, you need to search for the manual for the remote.
11/20/2023 12:12:03 AM • Coby Televison &... • Answered on Nov 20, 2023
How to connect Coby tftv lcd 3229 to wifi
you don't. It is not wifi compatible link to manual copy and paste https://www.manualslib.com/manual/468639/Coby-Tftv3229.html#manual
10/20/2023 11:45:43 PM • Coby Televison &... • Answered on Oct 20, 2023
Coby TF-DVD7005. Forgot password on it for the parental controls.
Question edited for clarity. You need to do a factory reset, but it isn't listed https://www.google.com/search?q=coby+tf-dvd7005+reset+parent+code The default password is "0000" If you want to set it back to the factory default you can email Coby support at [email protected]. ..
4/18/2023 5:49:50 PM • Coby Televison &... • Answered on Apr 18, 2023
Coby TVDVD2050 20 in. TV/DVD Combo Logo
Popular Tags
25 questions posted
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
coby tv dvd will not power
  • Televison & Video
