20 Most Recent Sharp LC42SB48UT 42 in. LCD TV Questions & Answers
2answers
Spot of bad weather here,
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
7/6/2017 7:44:03 AM • Sharp LC42SB48UT... • Answered on Jul 06, 2017
Blank screen (but some light) on Sharp LC42SB48UT LCD TV
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/22/2017 11:54:27 AM • Sharp LC42SB48UT... • Answered on Apr 22, 2017
My 70 inch sharp LC-70TQ15U has white shadow spots when the picture is dark
re place lcd panel that is dead pixel
4/21/2014 10:14:05 AM • Sharp LC42SB48UT... • Answered on Apr 21, 2014
Color is off
try to reconnect all connector on cable box and your cable connection on your TV.
10/29/2012 10:11:22 AM • Sharp LC42SB48UT... • Answered on Oct 29, 2012
The picture of my sharp 42
Check its antenna orientation.
9/28/2012 11:38:57 AM • Sharp LC42SB48UT... • Answered on Sep 28, 2012
Tv takes at least 15 min, up to an hour to turn on. Any suggestions?
my initial guess would be the power supply, but a proper diagnosis will need to be done. Check for bulging capacitors on the power supply board. If you notice any, that's most likely your problem.
9/21/2012 8:36:22 AM • Sharp LC42SB48UT... • Answered on Sep 21, 2012
Broken lc-42sb48ut
I would look to see if this unit has a back light and if so it may be your problem--either the actual back light or the voltage source that powers it.Not likely to be a do it yourself repair.
4/30/2012 3:29:37 PM • Sharp LC42SB48UT... • Answered on Apr 30, 2012
What kind of audio system do I need to purchase
I changed my audio equalizer setting to "POP" and I got much more pronounced separation. Also, make sure the SURROUND is set to "ON" in your settings or simply hit the SURROUND button on the remote that came with the TV.
The "AUDIO OUT" jacks on this set apparently only work when the input is set to "TV". I wanted to hook a couple of external speakers up as well and found they would not work when hooked up to HDMI to a cable box. I mean how many people by a large flat screen like this if they don't want to view HD? Like about zero! The AUDIO OUT works only when TV is selected for INPUT
A work around is to use the headphone jack and hook a couple of external speakers up to that.
If you want to go for a higher end home theater sound bar system so that you can route both DVD and CABLE box through it via multiple HDMI's you can choose from SONY, Phillips etc.
I wrote to Sharp about the AUDIO OUT issue. It's rediculous that they only work when TV is selected for input. But you might try using the heaphone jack alternative if you find a set of speakers that sound good to you. Hope this helps.
12/27/2010 5:37:48 AM • Sharp LC42SB48UT... • Answered on Dec 27, 2010
How do get full screen on LC-15S2u
Menu on remote and make sure you have it on wide screen or 16 to 9
1/17/2019 10:35:18 PM • Sharp LC... • Answered on Jan 17, 2019
Why isnt roku 3 working through my LC-32DV24U roku 1 worked fine
Hello If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them. For any help or support just visit us: www Roku Com Link
5/26/2018 8:22:34 AM • Sharp LC... • Answered on May 26, 2018
Sharp LC42SB48UT 42 in. LCD TV Logo
18 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
color off
  • Televison & Video
