20 Most Recent
Sanyo PLC XU50 Multimedia Projector Questions & Answers
Hello Is there anyone who can help. My problem
It's allways best to check your User Manual for any LED signs, go to your providers website, input your device, and download if any manuals for it. there you will find what the trouble is.
i presume that the bulb on your projector has gone bad. hope this helps!
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Sanyo PLC XU50
It may be that the lamp actually does need replacing so that may be why it's not coming on?
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
Warning lamp glow
Hi
Does your projector still work?
The warning lamp is there to let you know there is a problem, usually overheating! Make sure it is well ventilated and that the filters have been cleaned.
Try disconnecting the AC power cord and then reconnect it to check if it is still happening.
Accidently hit the key lock button
Hi
You can overcome this problem by disconnecting the AC power cord, to turn off the power. Then press and HOLD the select button and reconnect the AC power cord.
This should clear the Lock.
Hope it helps
Sanyo Projector PLC-XU50 Lamp Hours
Turn projector on and before doing anything else, press and hold the UP arrow on the machine for 30-40 seconds WHILE watching the display screen on the wall - the remaining hours will display only momentarily - if you look away you could miss it. Cheers
PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
- Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
- Once on the Sanyo support website, click on the "Projectors" category.
- Select your projector model, which in this case is the XU 101.
- Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
- Look for the driver that you need and click on the download link.
- Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak.
To solve this issue, I recommend the following steps:
- Make sure that the air conditioner is properly plugged in and receiving power.
- Check for any visible damage to the unit, such as bent fins or loose wires.
- Check the air filter and clean or replace it if it is dirty.
- Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
- Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
