20 Most Recent
kawasaki SVP500 Multi-disc DVD Player Questions & Answers
DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Opens and closes
more likely to be a worn belt or in need of lubrication. could maybe have a disc or other object stuck inside try turning upside down and shaking it out.
The DVD player doesn't play DVD disc only CD discs
first thing to do is try a lens cleaner disk. If that does not help you can try to remove cover and maualy clean the laser pick up with a q-tip and isopal alcahol. If that is not something you want to try have it done by a friend that has experiance or a shop. If that does not fix it you will need a new laser assy.
Will not open nore will it power up
try unpluging for a few minuits, and plug back in. if that does not fix problem it has a bad power supply and needs to be repaired or replaced.
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off.
can be fixed with a small elastic goody hair tie w/o metal clasp
