20 Most Recent
Sanyo PLC-XT16 Multimedia Projector Questions & Answers
Sanyo plc-xt16 Projector
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
All filters are clean on unit but while warming up
hi,
check , is the fan is working or not. a fan is used for cooling the lamp,( through out till it is on.) if the fan is not working the lamp will get over heated and the worming message will come.check it first.
ok
The lower part of the display is dim.
the fly-eye lens (diffuser) is starting to fry and needs to be replaced. there is one right inside the lamp housing and one on the other side of the first. the second one is the one that usually fries. if that is ok, then check the light filters next to the lcd panels. they fry due to excessive dust and heat. if one of those go, you'll need to replace the entire optical engine.
When you power up the
Those whit screens are parasites (pixels incorrectly commanded) Since they appear white that means the parasites appear in all 3 LCD screen at once, meaning that they are generated by the image processor. The processor is faulty and since it's soldered on the mainboard it must be replaced.
The only place from which you can obtain a mainboard for your model is an authorised repair shop - or a shop attached to a dealer.
Get a quote before sending it to one of them, it 's very possible that the bill will be higher than what the projector is worth.
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
- Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
- Once on the Sanyo support website, click on the "Projectors" category.
- Select your projector model, which in this case is the XU 101.
- Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
- Look for the driver that you need and click on the download link.
- Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak.
To solve this issue, I recommend the following steps:
- Make sure that the air conditioner is properly plugged in and receiving power.
- Check for any visible damage to the unit, such as bent fins or loose wires.
- Check the air filter and clean or replace it if it is dirty.
- Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
- Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
