20 Most Recent
Sanyo ICR-B200 Digital Voice Recorder Questions & Answers
Delete files
Hi..
Do you want to delete your files, the easy way is you just plug you unit to your computer, after you unit will be detected you can see the files, now you can delete the files that you want to delete, just right click the files and delete.
Regards
PCmania
How do you delete files?
There is a yellow delete button, push and hold it, push it and confirm, or push and hold, let go, and push and hold again.
Sanyo TRC 1149 winding and playback faults
Hi,\015\012\015\012I'm sorry to hear that.\015\012\015\012This is a common fault on cassette decks and can be caused by a number of things.\015\012\015\012The most common is the motor being seized or worn.\015\012\015\012If the motor spins when you touch the belt then the problem lies in the drive mechanisms.\015\012\015\012There is a good chance that the drive belt has perished and needs to be replaced.\015\012\015\012If the deck is drawing too much current when you switch it on the fuse will blow.\015\012\015\012If the fuse is fine and the deck runs for a few seconds before cutting out then the problem could be one of the capacitors in the power supply.\015\012\015\012If the deck is more than 10 years old then it may be time to replace the capacitors.\015\012\015\012You can do this yourself if you are a little bit handy with a soldering iron.\015\012\015\012That's about it really.\015\012\015\012
Cannot play wmv or MP4 files - SANYO DMC 2040
You most likely are not meeting the specs required by the player. Check the manual on the cd for the specs the player can resolve or use the converter on the cd to convert your mp4's wmv to meet the specs.
What is the FM ANT and how do we use it on a Sanyo DC-DA1460M
Hello Hannes, FM ANT, is the connection of the antenna to receive FM radio stations (Frequency Modulated) Here you can connect a cable of approximately 1 meter, and use it as an antenna, depending on where you are, rural or remote areas. the city, you might need an external antenna, similar to those used for analog TV reception
I sent you a link to download the user manual of your Sanyo
Greetings Franco Dosil
Hola Hannes, FM ANT, es la conexion de la antena para recibir estaciones de radio de FM (Frecuencia Modulada)Ahi pedes conectar un cable de 1 metro aproximadamente, y lo usas como antena, dependiendo de donde te encuentres, zonas rurales o alejadas de la ciudad, podrias necesitar una antena externa, similares a las usadas para recepcion de TV analoga
te envio un link para que descargues el manual de usuario de tu Sanyo
Saludos Franco Dosil
https://mans.io/files/get/499596
https://mans.io/item/sanyo/dc-da1460m
https://elektrotanya.com/sanyo_dc-da1460m_micro_component_system_sm.rar/download.html
