20 Most Recent
Sharp AR-M237 Copier Questions & Answers
Error code F6-10 on Sharp AR-M236 how do i remedy
This indicates to me that there is a Fax module fitted to your machine. If this is the case it may have developed a fault. Do you use the fax? If not you could try removing it so that you can use your copier as normal.
Good luck
Follow me on Twitter @CDOS_Service
ERROR CODE E7-03
E7-03 indicates hard drive trouble. the hard drive is going bad. There is not a whole lot you can do besides trying to reseat all connectors for the hard drive (the harness/wire from the HDD to the ICU PWB board) otherwise replace the hard drive.
Please i need to reset my sharp ar-m236 password
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
SHARP AR-M207 displaying an optional fax kit is not installed. what should i do?
is there one in the machine. does it have the phone cord hook up on the side of the machine if not you do not have the fax capability, it was an option on this model. you would have a hard time finding one now. if it is there the fax board is damaged and would need to be replaced but like i said you would have a hard time finding one.
WHAT DOSE F2 MEAN
most of the time it is the chip on your toner cart. you need a new toner cart.
En la fotocopia dora me
Hola buenas tardes, me podrian ayudar tengo una copiadora sharp ar m237 y me esta marcando el codigo U2-40 y no se que hacer alguien pude hacesorarme
