20 Most Recent
Sharp Notevision XG-P10XU Multimedia Projector Questions & Answers
Having problems getting my powerpoint
try Fn key with F5 or F8. depends on your model of laptop.
Look for the screen symbol on one of the function keys and try pressing that once and wait several seconds to see the screen changing video. Then press again if not correct.
If nothing is appearing on the projector, then connect a lcd monitor on the laptop and try the function keys intil it works thyen swap the monitor for the projector, and start the input scan for the active video input.
My projector will only turn
what is the name of the electronic screen with flexible ribbon cord attached to it and it is located in between the front and inner focal lense's and where can I get a replacement part for it?
We have a Sharp Notevision XG P10XU and no user
I don't know if you can connect it to a TV, but... here is the link for the user manual.
http://static.fixya.com/Manuals/S/Sharp/Ntvsn_XG_P10_0305F41BCD81D014F0A9935B80579636.pdf
Cannot get my Sharp Notevision remote to advance slides
you need an infrared receiver that plugs into your laptop to receive the signal ...honestly they arn't very reliable...go buy a targus presentation remote at staples for 39-69 bucks if you want areceiver i think i have one left
I am using my xg-p10xu projector in my home
That wide screen black out areas are a pain. You can try seeing if the unit has an option to adjust for Wide Screen but as many projectors i work with none do that i work with. Check your manual and see what you can come up with but from what i know your stuck with the black unless you run non-WS versions =\
Installing new Lens
remove the lens cover (screw on bottom front of lens, and twist the cover off). if you don't see it from there, remove the 4 side screws and take off the top cover of the projector. you will definitely see it from there.
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
