20 Most Recent Sharp UX-B20 Plain Paper Inkjet Fax Questions & Answers
Doesn't print
3/5/2016 7:45:57 PM • Sharp UX-B20... • Answered on Mar 05, 2016
0answers
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
11/26/2012 4:28:12 PM • Sharp UX-B20... • Answered on Nov 26, 2012
I have a Sharp UXB20
The sad aspect of an inkjet printing mechanism, is that it must be used on regular intervals, else the ink dryes in the jets.
5/11/2011 7:17:22 PM • Sharp UX-B20... • Answered on May 11, 2011
How do you send fax?
put document face down, press speaker button, listen for dial tone, enter fax number you would like to fax document to, press grren send button.
1/30/2011 6:27:36 PM • Sharp UX-B20... • Answered on Jan 30, 2011
I am looking for a fax machine that will operate
You are being lied to, fax machines won't work reliably on a digital phone lines.
12/22/2010 4:24:22 PM • Sharp UX-B20... • Answered on Dec 22, 2010
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
12/18/2010 9:59:33 PM • Sharp UX-B20... • Answered on Dec 18, 2010
The memory is full and my fax keeps reading no
Don't worry about the memory being full, the problem is the ink, and once the machine is able to print the FAX will empty memory by printing the faxes out. This might sound bad but I have seen this happen, when you unpacked the new ink cartridge, did you pull off the little plastic protector? And is the paper loaded?
12/3/2010 2:25:38 AM • Sharp UX-B20... • Answered on Dec 03, 2010
0answers
Paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
6/3/2009 2:37:33 AM • Sharp UX-B20... • Answered on Jun 03, 2009
Ux-116
It is most often print side down,to make sure just make a copy first.If its blank then turn the original over and try again.
11/26/2008 4:08:19 AM • Sharp UX-B20... • Answered on Nov 26, 2008
I would like to setup my fax
11/10/2008 1:55:09 PM • Sharp UX-B20... • Answered on Nov 10, 2008
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
8/21/2008 10:59:07 PM • Sharp UX-B20... • Answered on Aug 21, 2008
2answers
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
7/23/2008 3:20:10 AM • Sharp UX-B20... • Answered on Jul 23, 2008
SHARP UX-BS60
7/14/2008 12:37:44 PM • Sharp UX-B20... • Answered on Jul 14, 2008
Sharp UXB-30 Fax Machine
I'm not familiar with this unit. Make sure you are using the original cartridges and not "compatibles." They claim to be the same but they are not. There are some that are fine but their consistency changes all the time. If you are using the right cartridges then it may be the head that's clogged. The head in your unit may or may not be replaceable. If it's a bad clog, the cleaning process will not help. Manually cleaning these nozzles is not recommended because they can be damaged easily.
5/7/2008 5:07:07 PM • Sharp UX-B20... • Answered on May 07, 2008
Line error when trying to send a document
Check the line for a dial tone on the machine. Either the handset, onhook or speaker phone button. This will test if any comunictions boards have failed in the machine. If you have a dial tone the fax is ok
Next try a manual transmission. Basically make a normal phone call with for example using the handset but have your original in the fax ready to go, ring the fax number when you hear the other fax pick up you press the start button.
Don't forget the other fax may have a problem.
2/1/2008 5:49:13 AM • Sharp UX-B20... • Answered on Feb 01, 2008
Sharp UX-B20 Plain Paper Inkjet Fax Logo
32 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
am looking fax machine will operate
  • Office Equipment & Supplies
