20 Most Recent
D-Link DIR601 WirelessN 150 Home Router and DLink DWA125 Wireless 150 USB Adapter Bundle Questions & Answers
Wifisettings
The best solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
How do i connect my wireless d-link to my
Using a LAN cable connect the router to your internet modem. Usually use LAN port 1 on each unless indicated otherwise.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The using the setup wizard, configure your WAN according to the requirements of you modem PPPoE, Dynamic, etc. In some case the router will sense the correct set-up.
We have a wireless dlink router and cant seem to
Try a factory reset. You can do this by login into you router and under Admin settings press the factory reset button. You will have to reset the router from scratch using the wizard. The otehr way to do a reset is there should be a small hole on the back side of the router - where powered on, us a pencil tip if paperclip to push in this hole for about 10 seconds and this should reset your router to its out of box factory settings.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Connect samsung smart tv
Of course the easiest way is a direct LAN cable bertween your TV and Router On your Samsung TV, go to Network Settings and look for your router in the wireless list. Select you router and if password protected enter the password. Also you can use the WPS connection method by selecting that on the TV and pressing the WPS button on the router (usually within a 2 minute time fame).
Another trick is to enable the Guest Mode on you router with no password (this only gives internet access). Then connect in the same manner as above but you will not need a password from the TV.
How do I make my Dlink wireless router secure
There are several methods for "Securing" your router. I'll answer in general first, and if you need more info, just ask. Here are the top three methods to make your Router "Secure":
1. Create a Password for the ADMIN access to your router. This ensures that no one can get to your router through your IP address, and make changes (like adding their own computer to your DHCP Table). Be sure and record this somewhere safe.
2. Along with this password, Create a "Passphrase/Security Code", and install this code in your Router's Wireless Settings. I recommend sixteen digits, mixed alpha and numeric (recommend using lower case alpha only).
3. Create a Table of TCP IP addresses which emcompasses ALL the devices you will be allowing access to this router. For added security, make your range OUTSIDE the default range. Example: 192.168.0.210 to 192.168.0.214. That would give you Five devices, and ONLY those five devices could connect (this is your own situation). Then set the "Number of Devices" to just "5".
4. There's actually a fourth step called "Locking it Down" to those devices ... but first get to the point where you can actually SEE these devices connected within the router's DHCP Table. GOOD LUCK!
Dir-601 doesn't work with windows 8
I don't think it's Windows 8. Connect a ethernet cable fron D-Link to computer. Is your Wireless Adapter Enabled on the computer. Unplug the D-Link, shut down the computer, unplug, remove battery, plug in D-Link , allow it to selftest, plug in computer, boot normally.
Short circuit
This is a network router, not a woodworking router? If sparks came from it... then it's as gone as it can get - no way to repair it.
My tablet want the network ssid what is this
The SSID is the name of the network. This is a publicly broadcasted name given to the internet access point by the router, or created by the network administrator. This can be seen by just searching for wifi networks. The only time an SSID does not get shown publicly is when the network administrator hides the SSID. This is done for more security because if you cant see the network, it is much harder to break into. Hope this helps
No connect wifi
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL.. http://192.168.0.1 The default login = admin The default PW = blank (just press Enter) You can now change the default admin password. You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
