20 Most Recent Sharp EL-1801P Calculator Questions & Answers
How to stop the Sharp EL-1801P rounding up the decimals?
For me, it works when I switch the second switch on the top from right to left ( Arrow up5/4 arrow down. I write the word arrow, because I do not know how to type an arrow, but in the calculator is an actual arrow on the switch. I hope this helps.
11/20/2023 8:19:56 PM • Sharp EL-1801P... • Answered on Nov 20, 2023
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
1/28/2021 12:29:01 PM • Sharp EL-1801P... • Answered on Jan 28, 2021
What are the setting for simple addition and subtraction. I also need it to print it for me
The manual mentions an add mode, turning the calculator into an adding machine. If this is the case, you can do this test and see if it works to confirm that it is acting like an adding machine. 4+ 3- 5+ * Think of these as integers. The 4 is positive, the 3 is negative, the 5 is positive. When we add all these integers together, we get positive 6. Good luck. Let me know if you have any questions. Paul
9/25/2015 1:34:10 AM • Sharp EL-1801P... • Answered on Sep 25, 2015
Why will the machine not allow me to put figures in?
there is an error.somebody w/knowledge has to open yhe machine. probably the printer is stuck.or there is something broken into this machine
11/10/2014 6:43:07 PM • Sharp EL-1801P... • Answered on Nov 10, 2014
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out. or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out. probably it willcome with anything that is stuck beneath the printer M.P
9/18/2014 9:36:41 PM • Sharp EL-1801P... • Answered on Sep 18, 2014
Ribbon Smudge
The only thing I can think of is the ribbon is not threaded properly. (ex. in front of carrier instead of behind or vice versa)
1/29/2014 2:40:20 AM • Sharp EL-1801P... • Answered on Jan 29, 2014
Sharp EL-1801P Calculator Logo
179 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
set time
  • Office Equipment & Supplies
